How do I pair the LOCKIN Smart Lock BOX L1 safe with my new phone via Tuya?
iwek77 2826 6
  • Need pairing reset procedure for new phone
    #1 20944875
    iwek77
    Hello, The problem is with the LOCKIN Smart Lock BOX L1 safe.
    Everything worked great on the old phone, I paired the safe with no problem and worked through the Tuya app.
    The problem occurred when I changed my phone to the new one. I cannot pair the safe with the new phone. Can anyone suggest how to do this? There are no instructions for this situation. When pairing, it tells me to turn on the device/safe/. I don't know how I can get it into the pairing state so that the green light blinks? Maybe someone has had this situation? Please help. Thank you in advance.
  • #2 20944932
    freebsd
    Help: 766
    Rate: 2032
    On your new phone you launched the Smart Tuya app and logged into your account, yes?
    Then you see all your devices. You don't have to pair them again.
  • #3 20944983
    iwek77
    Yes I logged in but I don't have any devices I don't know where the problem is ?
  • #4 20944997
    freebsd
    Help: 766
    Rate: 2032
    iwek77 wrote:
    Yes I logged in but I have no devices I don't know where the problem is ?
    The same login was used on both phones?
  • #5 20945016
    iwek77
    Thanks a lot, as I was looking for the wonderful buttons on the safe to pair up, and it turned out we had 2 different accounts on Tuya. Everything is now working fine. Thank you very much. Greetings
  • #6 20945030
    freebsd
    Help: 766
    Rate: 2032
    Super :-)
    Tip for the future, maybe it will come in handy one day: if you would like to pair the device with another Tuya account, you must first remove it from the previous account.
  • #7 20945041
    iwek77
    Thanks a lot, it can be useful :-) .
✨ The user experienced difficulties pairing the LOCKIN Smart Lock BOX L1 safe with a new phone via the Tuya app after successfully using it with an old phone. Initially, the user could not see any devices on the new phone despite logging into the same account. It was later discovered that the user had inadvertently created a different Tuya account, which was the source of the issue. Once the correct account was identified, the pairing was successful. A helpful tip was provided that to pair a device with a different Tuya account, it must first be removed from the previous account.
