Tuya Smart Watering Device Not Connecting to Smart Life App, WiFi Icon Flashing
jandek_84 3024 7
  • Connection fails despite 2.4 GHz routers and AP mode
    #1 21618045
    jandek_84
    Hi, I have a problem with the above described device. I bought it used, 100% working as described. Unfortunately I can't connect it to Smart Life. It is detected as a "smart watering device", the Wi-Fi icon flashes, but when trying to add it displays the message "adding device failed". I've tried on two 2.4GHz routers, I did an AP on the phone. Unfortunately it fails to connect.
    Moderated By p.kaczmarek2:
    Separated from: CB3S Tuya - no WiFi connection, hidden WiFi menu
  • #2 21618475
    Rate: 12972
    The first thing I would recommend checking is Bluetooth and allowing location access for the Smart Life app. I remember when I had that turned off there were weird pairing issues. And the second thing is, are you pairing with the Smart Life app - that's the exact name? Try it with the normal Tuya app.
  • #3 21618648
    jandek_84
    I also checked the Tuya and Moes app. Smart Life has all the permissions. I have more than a dozen Tuya devices and for a test I removed and re-added one of them with no problem.
  • #4 21618651
    Rate: 12972
    Do you do a long reset? Do you have instructions maybe? They often have two pairing modes there - via AP and via BT, have you tested both?
  • #5 21618804
    jandek_84
    [postid:14372ebb18][/postid:14372ebb18] There is nothing in the manual about a long reset. I have tried AP and Bluetooth
    Botany Grow device setup guide with Wi-Fi pairing and SmartLife app QR codes .
  • #6 21621610
    skaktus
    Level 37  
    Help: 89
    Rate: 315
    >>21618804 .
    Change the name of the network. I at my place had to remove the dot from the name. Suddenly it started working.
  • #7 21621616
    jandek_84
    >>21621610 I have two networks with frequency in the name and on the second router without (just "sh"), unfortunately it does not work.
    Probably Wi-Fi module faulty.
  • #8 21621628
    skaktus
    Level 37  
    Help: 89
    Rate: 315
    >>21621616 .
    I tested and agonised for a good few hours. It only started without the dot, without the space. It's been ~a month since then and the whole thing works.
    I have written a priv to you.
A used Tuya smart watering device fails to connect to the Smart Life app despite being detected and showing a flashing WiFi icon. The connection attempt results in an "adding device failed" error. The user tested connection on two different 2.4 GHz routers and via AP mode on a phone, but the device does not connect. Suggestions include verifying Bluetooth and location permissions for the Smart Life app and trying the official Tuya app for pairing. The user confirmed all permissions are enabled and successfully re-added other Tuya devices, indicating the issue is specific to this watering device. The device manual lacks instructions for a long reset, and both AP and Bluetooth pairing modes have been attempted without success.
