Creating Variables and Utilizing Channels in OpenBeken: A How-To Guide
max_mcu 1131 1
  • #1 20942231
    max_mcu
    How can I create variable e.g.
    Dim intX As Integer
    I found no information on how to create variables and how to freely use only the CHxx, no idea what the CHxx is.. int, long, string?
    CHxx = CHxx + 1 doesn't work
  • Using channels as floating point variables
    #2 20990110
    Rate: 12937
    Currently we're using channels as variables. They are floating point numbers.
    So, to set a channel, you can do:
    setChannel 1 123
    Then you can, for example, use channel value in math expression like:
    setChannel 2 $CH1*10
    See a list of expressions:
    https://github.com/openshwprojects/OpenBK7231T_App/blob/main/docs/constants.md
    You can also use that in conditionals:
    if $CH2<10 then toggleChannel 12
    If you want to learn more about scripting, see our autoexec.bat samples:
