[Solved] How to set up a scene in Tuya for T&H Sensor and Mini Smart Switch.
Goldenar 2433 1
  • Tuya scene using below 19° and above 20° triggers
    #1 21062755
    Goldenar
    Rate: 17
    Smart Life or Tuya Smart.
    I have a Mini Smart Switch and a T&H Sensor. I tried to create a scene where the T&H Sensor would control the Mini Smart Switch. Below 19 degrees Celsius the temperature sensor would switch the relay on and above 20 degrees it would switch it off. After many attempts I finally managed to put this together.
    If T&H Sensor: below 19 degrees, Then Mini Smart Switch: ON . If T&H Sensor: above 20 degrees, Then Mini Smart Switch: Change state. I already.
  • #2 21065451
    Goldenar
    Rate: 17
    It is in the text above.
