Tuya - how to set the scene: humidity sensor <47% turns on the plug for 5 minutes
batory92 735 1
  • #1 21593285
    batory92
    Hi all :) I have a problem creating a scene in the Tuya app. Is there anyone who is familiar with this and can explain to me how to make this one scene?
    I have a soil sensor and when the humidity drops below 47%, I would like the plug to turn on for 5 minutes. I can't set a countdown timer on the plug xD Please help and thanks in advance.
  • Automation scene with humidity trigger and 5-minute delay
    #2 21593558
    gulson
    System Administrator
    Help: 150
    Rate: 6162
    If there is no timer in the plug-in device itself (Device Settings) then you could try creating a scene in the automation.
    Something along the lines of When (when) humidity below <47% then (then) turn on the switch, add a 5min delay (Delay), turn off the switch. (three steps for it to execute)
    There are different interfaces to these apps, I had 3 apps for Tuya for a while - each looked different.
