Does the Tuya WiFi touch switch support the Mobilus MM35 roller shutter motor?
przemyslawlibera 1200 1
  • Stop button likely incompatible with Mobilus MM35 motor
    #1 21087588
    przemyslawlibera
    Good morning,
    I have purchased switches/switches for roller shutters:
    https://allegro.pl/oferta/wlacznik-dotykowy-s...-zaluzji-karniszy-wifi-tuya-bialy-10699995190
    The motor for the roller shutter is a Mobilus (Mm35 I think). While the buttons for lowering and opening the roller shutter work (you don't have to hold them, the roller shutter opens/closes all the way), the stop button doesn't work.
    Everything seems to be connected well. There is an N wire.
    Does this switch operate this motor?
    On the remote control the stop button works and the roller shutter can be stopped e.g. in the middle.
