ZxSpectrum emulator on ESP32 "ESPectrum"
MikeC 7881 13
  • ESPectrum brings ZX Spectrum family emulation to ESP32 boards, covering 48K, 128K, +2, Pentagon 128K and ZX81.
  • It runs on Lilygo TTGo VGA32, Antonio Villena’s ESPectrum board or Olimex ESP32-SBC-FabGL, using VGA output, a PS/2 keyboard and an SD card.
  • The emulator claims 100% cycle accuracy and supports VGA 6 bpp output in 60 Hz, 70 Hz and 15 kHz 50 Hz modes.
  • A TTGO VGA32 V1.4 build costing about PLN54 reportedly behaves like a real ZX Spectrum, with no noticeable performance differences or game/demo issues.
  • Workstation with a monitor, keyboard, and connected ZX Spectrum emulator. .
    Hello everyone, I present a great emulator for Zx Spectrum family computers (48K, 128K, +2, pentagon, ZX81). This is an emulator that works on boards using the Espressif ESP32 SoC.
    Currently it can be used with Lilygo's TTGo VGA32 board, Antonio Villena's ESPectrum board and Olimex's ESP32-SBC-FabGL board, or of course you can make it yourself according to schematics e.g.: VGA32 V1.4.
    All you need to do is connect a VGA monitor or CRT TV (special VGA-RGB cable required), a PS/2 keyboard, prepare the SD card and connect the power supply.
    Key features:
    * ZX Spectrum 48K, 128K and Pentagon 128K emulation with 100% cycle accuracy (no PSRAM required).
    * State-of-the-art Z80 emulation (by José Luis Sánchez).
    * Choice of Sinclair 48K, Sinclair 128K and +2 English and Spanish ROMs.
    * Possibility to use one custom 48K and one 128K ROM with easy flashing procedure from SD card.
    * ZX81+ IF2 (ROM courtesy of Paul Farrow) with file loading from SD card.
    * VGA 6 bpp output in three modes: VGA standard (60 and 70 Hz), VGA 50 Hz and CRT 15 kHz 50 Hz
    * Supports 16:9 or 4:3 aspect ratio (in 360x200 or 320x240 modes)
    * Emulated multicolour attribute effects (Bifrost*2, Nirvana and Nirvana+ engines)
    * Emulated graphic effects (Aquaplane, The Sentinel, Overscan demo)
    * AY-3-8912 sound emulation
    * Dual PS/2 keyboard support: two PS/2 devices can be connected simultaneously.
    * PS/2 joystick emulation (Cursor, Sinclair, Kempston and Fuller)
    * Support for two real joysticks (up to 8 buttons) using the ESPjoy adapter or standalone DB9 to PS/2 converter.
    * Emulation of audio and tape deck input.
    * Complete OSD menu in two languages: English and Spanish.
    I made my emulator based on a TTGO VGA32 V1.4 board bought on ali for about PLN54 including shipping. Initially I wanted to do it myself, but the chronic lack of time and the low price outweighed this decision.
    All I had to do was program the ESP with software from the github repository (https://github.com/EremusOne/ZX-ESPectrum-IDF) using flash_download_tool_3.9.2 with settings as in the pictures below.
    ESP32 Flash Download Tool v3.9.6 with a highlighted ZX Spectrum file path.
    Screenshot of the ESP32 Flash Download Tool V3.9.6 software.
    As far as my eye is concerned the emulator is really very good, compared to a normal Zx Spectrum I don't see any differences in performance, I haven't encountered any demo or game that had problems on this emulator.
    options available from the emulator:
    ZX Spectrum emulator screen with the main menu on a monitor.
    Some pictures of the view of the ESP32 V1.4 board , the operation of the emulator and its simplicity:
    TTGO VGA32 V1.4 board with an SD card.
    . Diagram of TTGO VGA32 V1.4 board with VGA outputs and PS/2 ports.
    TTGO VGA32 V1.4 board with connected VGA and PS/2 cables.
    Monitor with connected ZX Spectrum emulator and PS/2 keyboard on a desk.
    Television display with ESpectrum emulator running.
    And the schematics of the VGA32 V1.4 board:
    Electrical schematic of the VGA32 V1.4 board for ZX Spectrum emulator.
    Electrical schematic of the TTGO VGA32 V1.4 board showing component connections for PS/2, VGA, and SD card.
    Circuit diagram of VGA32 V1.4 board.
    ESPectrum Design and Documentation:
    Website
    https://zxespectrum.speccy.org
    Patreon
    https://www.patreon.com/ESPectrum
    Github repositories
    Youtube channel
    https://www.youtube.com/@ZXESPectrum
    Twitter
    https://twitter.com/ZX_ESPectrum
    Hardware:
    Lilygo FabGL VGA32
    https://www.lilygo.cc/products/fabgl-vga32?_pos=1&_sid=b28e8cac0&_ss=r
    ESPectrum project - Antonio Villena
    https://antoniovillena.es/store/product/espectrum/
    ESP32-SBC-FabGL de Olimex
    https://www.olimex.com/Products/Retro-Computers/ESP32-SBC-FabGL/open-source-hardware
    Drivers:
    Drivers chip USB-Series CH340
    https://www.wch-ic.com/downloads/CH341SER_ZIP.html
    Other:
    ESPjoy project - Antonio Villena , firmware David Carrión (conversion of DB9 joystick to USB or PS/2)
    https://antoniovillena.com/product/espjoy/
    ESPjoy firmware - David Carrión
    https://github.com/dacarsoft/DB9_2_Keyboard
    8bitdo Retro Receiver for Sega Genesis & Mega Drive
    https://www.8bitdo.com/retro-receiver-genesis-mega-drive/
    3D models - Lilygo
    https://www.thingiverse.com/search?q=Ttgo+vga32&page=1&type=things&sort=relevant
    Lilygo FabGL VGA32 project
    https://github.com/LilyGO/FabGL/blob/master/Schematic/vga32_v1.4.pdf
    I recommend a really nice project.
    Regards MikeC.
    • English ESPjoy Manual.pdf (6.04 MB) You must be logged in to download this attachment.
    MikeC
    Level 32  
    MikeC wrote 1391 posts with rating 972, helped 201 times. Been with us since 2002 year.
  • #2 21104893
    gulson
    System Administrator
    Help: 150
    Rate: 6122
    Great! Thanks for sharing the solution! I sometimes play using ZxSpectrum, Atari and Amiga emulators.
    Nostalgia of the 90s when I was a teenager.
    If you email me a packet and phone number I'll send a small gift.
  • #4 21105322
    MikeC
    Level 32  
    Help: 201
    Rate: 972
    LechU wrote:
    Unfortunately, this link is no longer active
    I have added the ESPjoy manual for download , the software on github is active ....
  • #6 21126569
    MikeC
    Level 32  
    Help: 201
    Rate: 972
    There are at least several implementations of the zx spectrum emulator on esp32 , I have tested two and the one presented ( according to the Spanish project) seems the best . As far as I know there is also an emulator vic20 and amstrada cpc . I will certainly test them .
  • #7 21127397
    DIORADIO
    Level 32  
    Help: 187
    Rate: 317
    This discussion reminds me of the times when we produced Ewa, Alina. There were also disputes, because part of the production was still tube radio receivers, and part of it was already producing transistors (Ewa, Alina). They had more self-esteem because they were already experts in transistors. But then everything evened out.
  • #8 21127452
    gulson
    Help: 150
    Rate: 6122
    Competition among teams where there is no need for collaboration is quite important.
    It's nice that more projects are being developed on ESP32.
  • #9 21128073
    VSS
    Help: 5
    Rate: 261
    I don't know if this question doesn't break the rules but I'll ask:
    Where do you get ROMs of programs and games for this emulator?
    What format and extension must the file have?
  • #10 21128181
    gulson
    Help: 150
    Rate: 6122
    A lot can be found on archive.org
    There are archives of old books, magazines, music and just games and programmes.
  • #11 21128480
    MikeC
    Level 32  
    Help: 201
    Rate: 972
    Have a look at for example: https://zxart.ee/ , the emulator supports the extensions TAP , TZX , TRD , SCL ....
  • #12 21130269
    VSS
    Help: 5
    Rate: 261
    >>21128480 .
    And how to fire TZX? because when I load it to the card, the emulator doesn't see it :(
  • #13 21131084
    MikeC
    Level 32  
    Help: 201
    Rate: 972
    >>21130269 .
    Load the file into the virtual tape recorder via F5 then e.g. tape loader with 128 and F6 start uploading ...
  • #14 21166652
    smithdaryn
    I am a bit confused on joystick options, types and interfaces. Is the ESPJoy the only option at the moment? Still waiting for my hardware so no testing thus far. Thank you
The discussion centers around the "ESPectrum" emulator for ZX Spectrum family computers, which operates on the ESP32 SoC. Users can utilize various boards, including Lilygo's TTGo VGA32, Antonio Villena's ESPectrum board, and Olimex's ESP32-SBC-FabGL. The emulator supports ZX Spectrum 48K, 128K, and Pentagon 128K with high cycle accuracy and features advanced Z80 emulation. Users inquire about ROM sources, file formats, and joystick options, with suggestions for obtaining ROMs from archive.org and zxart.ee. The community expresses interest in multiple implementations of the emulator and the importance of competition in development.
