LED Strip Control: Manual Wall Switch and App Integration with Sonoff or Tuya?
maajkel11 954 5
  • #1 21250934
    maajkel11
    Hello everyone.
    As you know, we offer switches (sonoff, tuya) that allow you to control the lighting at the same time via an app and via a "classic" touch switch.
    Is there such a thing for LED strips? I mean the possibility to manually switch on an LED strip that was previously switched off via the app and vice versa. Please advise.
  • Manual and app control with eWelink-compatible controllers
    #2 21250964
    borba
    Help: 14
    Rate: 30
    >>21250934 .
    It can be done. I have an "ecosystem" based on the eWelink app and both the lighting, gate and socket controllers are controlled by the eWelink app. Both wall switches, contact plugs and gate controllers can be activated both from within the app and manually, via pressure (wall switches) and a physical button (gate controllers, contact plugs.
    The hardware used for this is not only Sonoff, but also compatible components (there are quite a few).
    I have a controller for LED strips in my kitchen and it works identically, i.e. it is possible to switch the strips on manually and to switch them off remotely.
    Of course, if one does not want to use the Chinese "cloud", one can change the software in these devices to "open".
    Regards.
  • #3 21251664
    maajkel11
    Can you give such an example of an LED tape control kit? I'm also keen for the switch not to be the size of a classic wall switch, but small in size (I'm thinking of illuminating a shelf with LED tape).
  • Identified the controller as a Sonoff Basic R2
    #4 21251677
    borba
    Help: 14
    Rate: 30
    >>21251664 .
    This is going to be a problem with this. I have two LED strips under the cabinets that are touch activated. To these at the electrical cube above the vent I have this controller connected. It's some sort of mini eWelink, in the shape of such a cube about 3 x 3 cm. When I island, I'll take a photo and post it. Unfortunately, the one I have in the LED strips (taped under the cabinets), the tactile one, I can't identify.
    Regards.
    Okay, I made it up. Sonoff Basic R2. I bought something like this years ago in several copies and there's just one of them sitting on a shelf under the ceiling.
  • #5 21253327
    maajkel11
    Touchscreen, I understand one that is recessed into the LED profile under the diffuser? Thanks for the advice :) .
  • #6 21253332
    borba
    Help: 14
    Rate: 30
    >>21253327 .
    Yes, exactly, it is recessed and fitted into the profile.
