Proposal for a few smart devices for a good start (integration with HA)
AoT_Hunter_PL 969 9
Which smart devices are worth buying to start automating a home with Home Assistant while keeping everything local and avoiding the cloud?
Start with a Zigbee setup: the SONOFF Zigbee 3.0 USB Dongle Plus-P was recommended as a good coordinator, and Avatto Zigbee relays and dimmers were reported to work trouble-free with Home Assistant for months [#21273358] For temperature and heating, a Zigbee or Wi‑Fi temperature/humidity sensor with display was suggested, along with an Avatto thermostatic head; for a simple battery-powered wall panel with up/down buttons and current/set temperature, one reply said they had not seen an exact match and that most such products are smart touch panels that connect to HA [#21273358][#21274645] For lighting, use an Avatto in-box relay with or without neutral depending on your wiring, and for roller shutters search for a Zigbee roller shutter controller; the Avatto brand was noted to have only a Wi‑Fi version for shutters [#21273358] Good extras for learning and testing were a flood sensor, smoke sensor, 3-phase electricity meter, and LoraTap multifunction remotes if you still want a physical control option [#21273358] Another useful direction is ESP32-based devices, since they integrate well with HA over Wi‑Fi and can be used for custom modules like air purifiers, WLED lighting, air-quality sensors, or gesture switches [#21272829]
  • Requesting cloud-free Home Assistant device recommendations
    #1 21272133
    AoT_Hunter_PL
    Help: 13
    Rate: 47
    Buying smart devices for a good start.
    Hello all, I would like to purchase some basic devices for the purpose of apprenticeship and testing the possibilities in HA.
    Please recommend a few models of the indicated smart devices to automate basic things at home (purchase will be domestic or via Aliexpres)
    From my requirements integration with Home Asistant, possibility to free from the cloud
    through reprogramming (Tasmota) or other alternative support.
    - panel - thermometer (internal - external) , or thermometer with controller (later integration with the head of the radiator)
    - water flow control head (radiator) -- later integration with the above-mentioned thermometer
    - 230VAC switch (plug-in adapter)
    - flush-mounted box with relay for lighting control
    - servo to control an internal roller shutter on a "chain".
    Alternatively, I would listen to interesting suggestions as to what else might be useful for educational purposes.
    Regards
  • Zigbee coordinator, Avatto relays, and ESP32 suggestions
    #2 21272829
  • Prioritize local LAN control with HA add-ons
    #3 21273138
    AoT_Hunter_PL
    Help: 13
    Rate: 47
    Welcome,
    Of the devices I am interested in, these are the basic components to dry test the automation system. I will then slowly implement this realistically in my home.
    Mainly:
    - CO furnace control + radiator surround (heat pump in future)
    - external and internal roller shutters
    - lighting
    - irrigation
    - video surveillance
    etc.
    I am rather interested in smartphone integration without additional remote controls.
    Of course, once I have familiarised myself with the hardware, I plan to modify or perhaps create my own controls in the future, but for the time being, ready-made + modules from ali are sufficient.
    If necessary, I can purchase a gateway to communicate with zigbee devices, etc. (but the priority is to make it work with the loco). (but the priority is to make it work locally on the LAN and not overload the WiiFii)
    I plan to automate the control by using add-ons on HA
    (Red Node etc).
    Greetings
  • Recommend HA on VM with Zigbee coordinator
    #4 21273298
  • #5 21273320
    AoT_Hunter_PL
    Help: 13
    Rate: 47
    Thanks to
    I already started the game some time ago because on board the host , there will be a couple of other servers actually already there.
    Some things will be tested proverbially "on the desk". , a few of them will definitely end up in the elements that I will want to automate.
  • Recommended SONOFF Zigbee coordinator and Avatto devices
    #6 21273358
  • #7 21274623
    AoT_Hunter_PL
    Help: 13
    Rate: 47
    Thanks for the sample materials, I'll check it out.
    There is a small wall-mounted smart temperature controller for heating on the market (but not as a thermostat - it does not need a built-in relay, 230VAC power supply from a flush-mounted box). I would prefer a simple battery-operated device with up , down control , displayed current , set temperature.
    Regards
  • #8 21274645
  • Asking how Avatto thermostatic head compares with Tuya models
    #9 21291592
    Jericho24
    Rate: 162
    Link
    Twitter head.
    Do you know how this head performs against those from tuya?
    I'm thinking of another one like the one below, but on a zibee.
    https://pl.aliexpress.com/item/10050055998184...%3ApcDetailTopMoreOtherSeller%7Cquery_from%3A
  • #10 21291802
The discussion focuses on selecting basic smart home devices compatible with Home Assistant (HA) for initial testing and learning, emphasizing local control without cloud dependency, preferably with Tasmota or similar firmware support. Key device categories include temperature and humidity sensors (internal and external), radiator valve controllers, 230VAC switches (plug-in adapters), flush-mounted relay boxes for lighting, and servos for roller shutter control. Zigbee coordination is considered, with the SONOFF Zigbee 3.0 USB Dongle Plus-P recommended as a reliable gateway. Wi-Fi and Zigbee are the primary communication protocols discussed, with a preference for local LAN operation to reduce Wi-Fi load. ESP32 modules are suggested for custom device creation and integration. Specific device recommendations include Avatto relays and dimmers, Sonoff temperature/humidity sensors, and flood sensors. The conversation also touches on the availability of smart temperature controllers for heating with simple battery operation and manual temperature adjustment, though such devices are rare and often integrated with main thermostats. The user expresses interest in smartphone integration without additional remotes and plans to expand automation to heating, roller shutters, lighting, irrigation, and video surveillance. The discussion briefly compares Tuya-based devices with alternatives, noting Tuya is a platform rather than a brand.
