Econet300 v3.2.3875 Firmware Update: Flash with TFTP Instructions
kaspargraumann 4413 6
  • #1 21377038
    kaspargraumann
    New firmware image for Econet300 v.3.20
    flash with TFTP.
    Just rename to Tp_recovery.
    Version 3.2.3875
    AI: Can you provide the detailed steps you are following to flash the firmware using TFTP?
    Standard
    AI: What is the current firmware version on your Econet300, and are you experiencing any specific issues that prompted the update?
    Version 3.2.3875
    • econet.bin (8 MB) You must be logged in to download this attachment.
  • #2 21429127
    pirtio
    >>21377038
    Thank you!
    I flashed the router with your firmware. Can I somehow access the settings from a PC?
  • #3 21449315
    kaspargraumann
    Hello, this firmware does not have its own webui, but it can be configured from the pc, which can get the ip address of the configuration from the boiler info display, it can be different for each case. Default password is admin. There is newest version of fw.
    • Econet24_v.3.2.3877.bin (8 MB) You must be logged in to download this attachment.
  • #4 21537719
    kasiog
    Another update for econet300 module firmware.
    • econet300_v3.2.3879.bin (8 MB) You must be logged in to download this attachment.
  • #5 21621157
    wkapsel1
    Can this update be done on a "normal" MR 3020 router? Or must it be the original from Econet?
    I.e. will it work normally or is it better to stay on the old version?
  • #6 21621653
    kasiog
    Hello, of course, this update can be applied to any tp-link router mr3020 only with version 3.20 improvement makes it more stable
    This is original firmware from Econet.
  • #7 21933482
    matiks2
    Hey, does it work with selected manufacturers such as Kipi, Kostrzewa and Pellas?
Discussion about flashing Econet300 firmware version 3.2.3875 via TFTP by renaming the image to Tp_recovery. After flashing, the firmware can be configured from a PC, but it has no built-in web UI; the configuration IP is obtained from the boiler information display and the default password is admin. A later update notes that the firmware is an original Econet release and can also be applied to a TP-Link MR3020 router with version 3.20, improving stability.
