Resolving Alarm F08 on SEW MDX61B Drive with KA47B CMP71M Motor
majidhanif2007 4920 3
  • Resolver calibration needed for F08 alarm
    #1 21436958
    majidhanif2007
    Sew servo Drive MDX61B
    Sew Servo Motor KA47B CMP71M 30.8 Nm
    Problem: Alarm F08
    Ipos & Servo..
    I face F08 alarm on sew drive. Checked all wiring between motor and drive.. all ok. Motor insulation test ok. Motor removed from gearbox and again F08.
    In fact, it needs resolver calibration.
    Can any one tell me how I can do that? And should I do it with same parameters and inverter with machine wiring, remove motor from the gearbox and do resolver adjustment? I see option is there but I need advice on it ?
  • #3 21438704
    bhtom
    Help: 446
    Rate: 604
    Welcome,
    majidhanif2007 wrote:
    I am dealing with an F08 alarm
    You could try increasing the times in parameters 501 and 503.
    Greetings.
  • #4 21451861
    zembol
    Help: 79
    Rate: 56
    Fire up scop and at what current it jumps into F08, then have a look at 303 (organically current).
