Hoover WD9616C-80 Washing Machine: Error E08, CIM 2/55-132/CY1 Motor Issue & Encoder Replacement
bigmaster 15066 11
Why does my Hoover WD9616C-80 washing machine stop with error E08, and is the motor encoder or control module the likely cause?
The fault is likely in the control module, not the motor itself [#16779916] Replacing the motor with a used one still produced E08, which points away from the engine and toward the module that drives it [#16779895][#16779916] One responder specifically asked for a photo of the motor-connected module to diagnose it [#16780025][#16780050] In other words, the encoder/motor swap may not fix this if the control board is the real culprit [#16779916]
  • #1 16770931
    bigmaster
    Rate: 91
    My two year washing machine she ended life with error E08
    model: Hoover WD9616C-80
    engine: CIM 2 / 55-132 / CY1 41023825
    The washing machine accelerates comes moments and after a while E08 freezes, after disconnecting from the power supply even for a few hours runs the same program. Should it be that way? should the program not turn off? From this video I know it's an engine error link it looks like a silinik without brush . So the encoder fell apart (position / speed auto analyzer) . Are you going to replace it? Resistance at idle and when turning:
    Hoover WD9616C-80 Washing Machine: Error E08, CIM 2/55-132/CY1 Motor Issue & Encoder Replacement Hoover WD9616C-80 Washing Machine: Error E08, CIM 2/55-132/CY1 Motor Issue & Encoder Replacement Hoover WD9616C-80 Washing Machine: Error E08, CIM 2/55-132/CY1 Motor Issue & Encoder Replacement
    :arrow: link Because the price of the engine kills
    link
  • #2 16770963
    398216 Usunięty
    Help: 3925
    Rate: 9447
    bigmaster wrote:
    the washing machine jumped with errora
    From on high?
    bigmaster wrote:
    contactless salivary gland
    bigmaster wrote:
    Encoder will come together
    Can you translate it to ours?
  • #3 16779895
    bigmaster
    Rate: 91
    Today came the used engine, seemingly functional. I connected it shook several times and error E08. He even once went to the end of the spin cycle at the end of E08. Could there be another cause of the fault?
  • #4 16779916
    hurtovnik32
    Help: 35
    Rate: 219
    This is not the fault of the engine - the module landed at 99.9%. I have an older model, but it is the same> I was looking for a fault and only after I was able to borrow and replace the module did I diagnose the fault. So far, the washing machine has been sent to a garage and has been standing there for over 2 years.
  • #5 16780025
    tolo
    Help: 233
    Rate: 1177
    Please paste a photo of the module.
  • #6 16780030
    bigmaster
    Rate: 91
    Thanks for the reply
    Which module?
    The one to which the engine is connected? Is the board up (both panels)?
  • #7 16780050
    tolo
    Help: 233
    Rate: 1177
    The one to which the engine is connected.
  • #9 16780730
    398216 Usunięty
    Help: 3925
    Rate: 9447
    bigmaster - Did you even read what you wrote? Swallowing letters, errors, random use of Polish letters, it is not enough that it is impossible to read and understand it is difficult:
    bigmaster wrote:
    on the new old engine sometimes starts, on the old one not once
    On the new old, or what?
    Please correct your posts, not only out of respect for readers, but also your native language.
  • #10 16781176
    bigmaster
    Rate: 91
    new / old >> I bought a used engine
    old >> that is originally installed in the washing machine
  • #11 16781284
    398216 Usunięty
    Help: 3925
    Rate: 9447
    bigmaster wrote:
    originally mutated in the washing machine
    398216 Usunięty wrote:
    Did you even read what you wrote? ......
  • #12 16791120
    bigmaster
    Rate: 91
    Well I will not hide that writing and reading is not my strong point, and self-correction in the cell does not help at all.
    I gave up I bought a new washer dryer BEKO, because I could not find anywhere a module for a used engine, and a new module replacement plus motor costs almost a new washing machine and if something goes wrong, the next costs.
    Thank you for your help and for clicking
The discussion revolves around a Hoover WD9616C-80 washing machine that is experiencing an E08 error, which is believed to be related to the CIM 2/55-132/CY1 motor and its encoder. The user reports that the machine intermittently accelerates before freezing with the error. After replacing the motor with a used one, the error persists, leading to speculation that the issue may lie with the control module rather than the motor itself. Users suggest that the module connected to the motor is likely the source of the problem, and the cost of replacing both the motor and module is prohibitive. Ultimately, the original poster decided to purchase a new washer-dryer due to the high costs associated with repairs.
TL;DR: Hoover WD9616C-80 throwing E08 is “99.9%” likely a motor-control module fault, not the motor. Expert note: “module landed at 99.9%.” [Elektroda, hurtovnik32, post #16779916]
Why it matters: This FAQ helps Hoover owners decide whether to inspect the control board, the encoder, or replace the washer, fast.
What does error E08 mean on a Hoover WD9616C-80?
In this thread, E08 flagged a motor-related fault. The user referenced a video indicating an engine error. The washer accelerated, then froze with E08 during spin attempts. The machine repeated the behavior after restart. Treat E08 as a drivetrain/control issue, not just a drum imbalance. Start by confirming motor type and connectors, then consider the control module if wiring checks pass. The case involved a brushless CIM motor with an encoder, which informs diagnostics. Document model and motor codes before ordering parts to avoid mismatches. [Elektroda, bigmaster, post #16770931]
Is E08 always a bad motor?
No. A seasoned member diagnosed the control module as the culprit with “99.9%” confidence. Their experience matched an older but similar platform. Quote: “module landed at 99.9%.” If you swapped motors and E08 persists, prioritize the motor-control board. Inspect for burned tracks, swollen components, or loose headers. Avoid buying a motor before verifying the board. This focus can save both time and money. [Elektroda, hurtovnik32, post #16779916]
Should the program cancel after I unplug the washer for hours?
In the reported case, unplugging for several hours did not clear the program state. The same program resumed and E08 returned on the next attempt. This behavior points away from transient glitches and toward a persistent control fault. Do not rely on power-cycling to resolve E08. Log the exact step where E08 appears for repeatability. This helps isolate sensor feedback versus power stage issues. [Elektroda, bigmaster, post #16770931]
Which module should I check first for E08?
Check the motor-control module, i.e., the board the motor harness connects to. Access it, photograph both sides, and look for damage or contamination. Reseat the motor connector and encoder plug. Inspect strain points where vibration can crack solder joints. If the board is clean, proceed with continuity and insulation checks on the harness. A clear photo greatly speeds remote diagnostics. [Elektroda, tolo, post #16780050]
I replaced the motor and still get E08—what now?
When a replacement motor doesn’t clear E08, shift focus to the control board. Community feedback identifies the module as the likely fault path. Recheck encoder wiring and connectors, then test the board’s power and drive sections. Avoid further motor purchases until the board is assessed. If the module is defective, motor swaps will not help. [Elektroda, hurtovnik32, post #16779916]
What is a CIM 2/55-132/CY1 motor and what does the encoder do?
It’s a brushless motor used in this Hoover model. The encoder supplies position and speed feedback so the controller can commutate and regulate RPM. If the encoder or its wiring fails, the controller loses rotor position, triggering E08 during acceleration. Quote from the user: encoder is a “position/speed auto analyzer.” Inspect the encoder and plug before condemning boards. [Elektroda, bigmaster, post #16770931]
Can E08 be intermittent or appear only after a spin completes?
Yes. In this case, the washer sometimes reached the end of a spin, then flagged E08. Intermittence suggests marginal connections, thermal faults on the control board, or encoder issues that manifest under vibration. Reproduce the error with a controlled spin test. Document whether it appears at ramp-up, peak RPM, or ramp-down. That timing guides root cause isolation. [Elektroda, bigmaster, post #16779895]
Quick 3-step: How do I document the control board for remote help?
  1. Remove the cover and photograph the motor-control board clearly, both sides.
  2. Reseat the motor and encoder connectors; note any heat discoloration.
  3. Run a spin program and record when E08 appears. These artifacts enable targeted advice and parts identification. [Elektroda, tolo, post #16780025]
How old was the machine when E08 first appeared in this thread?
About two years old. The owner reported the washer-dryer was two years in service when E08 occurred. Early-life failures often indicate control electronics or component defects rather than mechanical wear. That aligns with the focus on the motor-control module and encoder path. Record your unit’s age for warranty or goodwill claims. [Elektroda, bigmaster, post #16770931]
Is repair economical compared to replacement for E08?
It depends on parts pricing and availability. In this case, the owner chose a new washer because the board plus motor approached the cost of a replacement appliance. Price boards and motors before deciding. If sourcing an affordable tested module fails, replacement can be rational. Keep your old unit for parts recovery if space permits. [Elektroda, bigmaster, post #16791120]
What control board part was referenced for this Hoover?
An “unprogrammed three-phase control board” was linked for the WD9616C-80. Verify your exact product code before ordering. Photos and labels on your original PCB help ensure compatibility. Expect to transfer mounting hardware and connectors. Keep antistatic precautions during handling. [Elektroda, bigmaster, post #16780088]
Do replacement control boards come programmed?
Not always. The part mentioned in the thread was explicitly unprogrammed. That implies additional setup may be necessary after installation. Consult the seller about programming or exchange services. Bring your full model and service code when ordering to avoid mismatches. [Elektroda, bigmaster, post #16780088]
Why does clarity in posts matter for troubleshooting E08?
Clear descriptions reduce misdiagnosis and part swaps. A moderator asked the poster to correct unclear wording because ambiguity hindered help. Provide exact model numbers, error timing, and actions tried. Photos of the module and connectors further speed resolution. Precise language saves time and money. [Elektroda, 398216 Usunięty, post #16780730]
Will a used motor fix E08 if the module is bad?
No. The thread shows a used, seemingly functional motor did not resolve E08. The machine even completed one spin, then failed again. This edge case reinforces checking the control module before buying motors. Replace the board first if diagnostics point there. [Elektroda, bigmaster, post #16779895]
