Satlink WS-6906 Charging Indicator: Yellow to Black Light Normal?
colinjamesbarrett 870 1
  • Original charger confirmed, no battery issues
    #1 21461879
    colinjamesbarrett
    Hi! I'm new to this forum so if I've posted this in the wrong section I apologize.
    Anyway I have a Satlink WS-6906 Meter. When I plug it in to charge the light goes yellow. After a while it goes black. Is this normal or should it go green?
    AI: Are you using the original charger that came with the Satlink WS-6906, or is it a different one?
    yes
    AI: Have you noticed any issues with the battery life or performance of your Satlink WS-6906?
    no
  • #2 21463006
    tomaszlonski
    Help: 347
    Rate: 901
    Not normal
    Either the power supply or the power/charging circuit in the meter is damaged. Other damage to the meter itself also possible.
