How to Configure ESP32 for Stable Wi-Fi: Power Save, 20MHz Channel, Fixed Access Point
gulson 2508 2
  • Disable ESP32 power save and use 20 MHz Wi-Fi
    #1 21482181
    gulson
    System Administrator
    Help: 150
    Rate: 6085
    Three key solutions
    1. Turn off the power saving in the ESP32 .
    In the Arduino or esp-idf code add the line:
    esp_wifi_set_ps(WIFI_PS_NONE)
    For ESPHome add in the configuration:
    wifi:
    power_save_mode: NONE
    2. Set the Wi-Fi access points to 20 MHz channels .
    In the router settings:
    - Go to the router's administration panel
    - Find the 2.4 GHz Wi-Fi settings
    - Change the channel/bandwidth to 20 MHz (not 40, not 60, not auto)
    3. Assign the ESP32 to a specific access point .
    If you have multiple access points:
    - In the administration panel of your router/mesh system
    - Find the "client steering" or "band steering" settings
    - Disable automatic transfer of devices between access points
    - Manually assign the MAC address of the ESP32 device to the nearest access point
    Based on the article:
    https://supakeen.com/weblog/esp32-wifi-superstitions/
  • #2 21483546
  • #3 21485695
    kmarkot
    Help: 127
    Rate: 360
    On my Asus the 2.4GHz channel selection changed from Auto to manually selected now 3.
    The trouble with ESPHome devices losing coverage is over.
