BTicino SCS - will a UTP twisted pair be sufficient for the bus extension instead of the original ca
barmo 333 1
  • Bus carries 27 V power and communication
    #1 21550164
    barmo
    I hope this question isn't cosmically stupid: I have a BTicino SCS system in my house and I need to move a box by just under 10m, which involves the need to 'add' 10m of cable. The system is based on a two-wire cable, which looks like it could be replaced with anything, but.... the original cable costs terrible money and is only available in spools of 100 m (https://www.legrand.pl/pl/e-katalog/produkty/my-home-kabel-bus-scs-100m-l4669). Do I really need to use the official cable, or is one pair of UTP twisted pair cable (which is 3x cheaper, probably has better performance and on top of that I have some leftovers of it at home) enough?
    AI: What exactly are the devices connected to this SCS bus that will use this extension? .
    The whole system at my place consists of a control panel, a server for management, about 20 buttons and switches for the light.
    AI: Is this SCS bus in your case only for communication between devices or also for powering them? .
    As far as I can see, the power supply (27 V) also goes on the bus.
  • #2 21550578
    adamjur1
    Help: 772
    Rate: 1003
    On 10 mb it should work on any cable, if you have concerns then connect for a while in the current configuration plus this 10m and let it lie for a week....
    Greetings. J.
    ps I once had to give a floor above a LAN and there was only an alarm cable. At 25m it was laughing 100 Mbps....
