Philips 49PUS7090912 TV Standby Light On, Not Powering Up—Troubleshooting Steps
fiboka 1455 2
  • No signs of life beyond standby light
    #1 21572942
    fiboka
    Hello. Philips 49PUS70909/12 TV won't turn on. The standby light is on but it doesn't respond to anything. What should I check?
    AI: Have you tried any troubleshooting steps so far, such as unplugging the TV for a few minutes or using a different power outlet?
    Yes
    AI: Does the TV show any signs of life (like sounds or blinking lights) when you try to turn it on with the remote or the physical power button?
    no
  • #2 21573137
    Telo
    Service technician RTV
    Help: 1538
    Rate: 2390
    Look for an SM for that TV model or chassis, then measurements of the power supply on the connector that is connected to the main board.
  • #3 21573939
    fiboka
    Kontrolka gotowości w moim telewizorze Philips 49PUS7090912 jest włączona, ale nie włącza się ani przyciskiem, ani pilotem. Dioda gotowości nawet nie miga.
