KEBA P30 - is it possible to regulate charging power infinitely via LAN and PV?
Janek088 783 1
  • #1 21598686
    Janek088
    Help: 8
    Rate: 31
    Does the KEBA P30 series charger have infinitely variable charging control? The manual does not make it entirely clear whether this can be controlled with an external device via lan. The idea is to charge the car with the surplus current from the photovoltaic and windmill production in order to give as little back to the grid as possible, but also to take as little from it as possible.
  • #2 21599245
    kmarkot
    Help: 127
    Rate: 362
    It looks like it can be controlled with the Home Assistant.
    https://www.home-assistant.io/integrations/keba/
    Maximum Current keba.set_curr
    The keba.set_curr action sets the maximum current to the given current attribute in Ampere. Payload example:
    'current': 16.0
    I would also use a bidirectional counter integrated into the HA
    I wrote about it in this topic
    >>21597964 .
