Integration of IoT devices with Tasmota and MQTT in a single Android app, local WiFi
1002 4
  • Local WiFi integration via MQTT broker and Android app
    #1 21605787
  • Node-RED as the best all-in-one IoT solution
    #2 21605991
    xury
    Automation specialist
    Help: 878
    Rate: 1498
    I'm getting rid of all kinds of clouds too. You haven't written what specific Android app you want to use.
    Both Domotich and HomeAssistant have one if you necessarily want an app. But you can also use MqttDashboard. You build this dashboard on your phone. You can also make yourself a nice dashboard on Nodered using Dashboard 2.
    Overall Nodered is the best solution that has been invented for IoT Samo NR can replace everything and you can integrate everything with it.
  • Frontend app for Node-RED control panel
    #3 21606155
  • #4 21609438
    gulson
    System Administrator
    Help: 150
    Rate: 6122
    For nodered there is this dashboard:
    https://dashboard.flowfuse.com/
    I guess it runs as a PWA app (shortcut to Chrome)
    And I didn't read exactly why not home assistant?
  • Need a local-only mobile frontend without cloud
    #5 21612598
