How to Reduce Battery Drain in Atmega32 Line Tracer with L297 L298 Stepper Motors?
279 15
How can I reduce battery drain in an ATmega32 line tracer that uses L297/L298-driven stepper motors?
To reduce battery drain, first verify that the battery is healthy and then isolate which part of the system is consuming power; if efficiency is the main goal, stepper motors are a poor choice and a feedback servo drive would be better [#21658978][#21658984][#21658986] Measure current at the batteries in idle and while moving, and try separating the logic board from the motor driver so you can see which section needs improvement [#21658978] The reported loaded current of about 1.0–1.4A from a 1.8Ah battery should give only about 1–2 hours of runtime, so 15 minutes suggests either the battery is weak or the real load is higher than expected [#21658980][#21658981][#21658982] Test the battery independently with a fixed resistive load, such as about 12 ohms at more than 12W, and compare its voltage drop over time to the datasheet discharge curve [#21658984] If you keep the stepper motors, microstepping or sine-wave coil drive can improve efficiency somewhat, but continuous-motion steppers still waste power compared with servo motors [#21658986]
  • Battery drain likely caused by stepper motor driver losses
    #1 21658971
    Vinit Apte
  • #2 21658972
    Joe Wolin
  • #3 21658973
    Vinit Apte
  • #4 21658974
    Joe Wolin
  • #7 21658977
    Joe Wolin
  • Measure idle and motor current separately
    #8 21658978
    Joe Wolin
  • #9 21658979
    Vinit Apte
  • #10 21658980
    Joe Wolin
  • #11 21658981
    Vinit Apte
  • #12 21658982
    Joe Wolin
  • #13 21658983
    Vinit Apte
  • Battery load test to verify discharge curve
    #14 21658984
    Joe Wolin
  • #15 21658985
    Vinit Apte
  • Stepper motors are inherently inefficient for continuous motion
    #16 21658986
    Olin Lathrop
A line tracer robot using an Atmega32 microcontroller, two stepper motors driven by an L297 and L298 H-bridge driver pair, and TSOP sensors with a 555 timer for line detection is experiencing rapid battery drain. The power source is a 12V, 1.8Ah battery. Current measurements show 120-150mA when motors run unloaded, but increase to 1.0-1.4A under load during actual operation, causing battery life to drop to approximately 15 minutes instead of the expected 1-2 hours. PWM control was implemented but did not significantly reduce current consumption. The inefficiency of stepper motors in continuous motion, due to fixed stepping causing mechanical momentum loss and energy dissipation despite catch diodes, contributes to high power usage. Suggestions include measuring current draw in different operating modes, isolating power consumption of circuit sections, verifying battery health with a resistive load test, and considering the inherent inefficiency of stepper motors for continuous drive applications.
TL;DR: Line tracers using L297/L298 steppers can draw 1.0–1.4 A under load; “If efficiency matters then you don’t want to use stepper motors.” [Elektroda, Olin Lathrop, post #21658986]
Why it matters: Builders want longer runtime without sacrificing tracking accuracy; this FAQ shows where the current goes and what to change.
How long should a 12 V, 1.8 Ah battery run my line tracer?
At 1.0–1.4 A on-ground draw, expect about 1–2 hours if the battery is healthy. That aligns with a back-of-the-envelope 1.8 Ah ÷ ~1 A ≈ ~1.8 hours. If you see far less, the pack may be weak or the current is higher than measured. [Elektroda, Joe Wolin, post #21658982]
Why does current jump from ~150 mA to over 1 A when it’s on the floor?
Load and stepper inefficiency cause the jump. Steppers waste energy as heat and momentum is lost between fixed steps. As speed rises, square-wave coil drive further reduces efficiency. Wheels on-ground add mechanical load, so current rises sharply. [Elektroda, Olin Lathrop, post #21658986]
Are stepper motors efficient for a line tracer?
Not particularly. They offer simple positioning but poor electrical-to-mechanical efficiency, especially with fixed-step, square-wave drive. As one expert noted, “If efficiency matters then you don’t want to use stepper motors.” Consider alternatives if runtime is critical. [Elektroda, Olin Lathrop, post #21658986]
Will microstepping or sine-wave drive help reduce battery drain?
Yes, somewhat. Driving each winding with an approximated sine (microstepping) improves power transfer and smoothness, cutting some losses compared with square steps. Use a suitable microstepping driver or a MCU with motor-control PWM to synthesize the waveform. [Elektroda, Olin Lathrop, post #21658986]
How do I test if the battery is the culprit?
Load-test it. 1) Disconnect from the robot. 2) Attach a 12 Ω, ≥12 W resistor as a fixed load. 3) Measure and log battery voltage every 5 minutes for an hour, then compare to expected discharge behavior. A fast sag indicates a weak pack. [Elektroda, Joe Wolin, post #21658984]
What baseline measurements should I take before optimizing power?
Measure total current at the battery in multiple modes: idle, sensors active, wheels off-ground, and driving on-ground. Then isolate sections (logic, motor drivers) and measure each. These baselines reveal which block dominates consumption. [Elektroda, Joe Wolin, post #21658978]
Do PWM tricks on the L298 reduce stepper current meaningfully?
Not much in this setup. The builder tried PWM and saw little improvement. With fixed-step square drive, steppers remain inefficient, so PWM alone won’t deliver large runtime gains. Microstepping or a different motor type helps more. [Elektroda, Vinit Apte, post #21658971]
What do the L297 and L298 actually do here?
The L297 generates step and phase control for a stepper, while the L298 H-bridge drives the motor coils with required current and polarity. Together they form a classic stepper-control chain used in the described robot. [Elektroda, Vinit Apte, post #21658971]
My robot dies after ~15 minutes—what does that imply?
That observed runtime indicates a mismatch with the expected 1–2 hours. It suggests either reduced battery capacity or higher real load than earlier measurements captured. Start with a controlled load test and re-verify on-ground current. [Elektroda, Vinit Apte, post #21658983]
Should I switch from steppers to DC servos for better efficiency?
If runtime matters, yes. A servo with position feedback typically converts electrical power to motion more efficiently than a stepper in continuous drive applications like line tracing. Expect better watt-hours per meter traveled. [Elektroda, Olin Lathrop, post #21658986]
What’s a simple way to compare no-load vs load current correctly?
Use a DMM at the battery leads and record current with wheels off-ground and then on-ground. Note the large delta; one report showed ~120–150 mA off-ground versus ~1.0–1.4 A on-ground, a useful diagnostic contrast. [Elektroda, Vinit Apte, post #21658981]
What’s a quick 3-step plan to extend runtime without new batteries?
1) Improve drive efficiency: enable microstepping/sine-like coil drive. 2) Reduce mechanical load: check friction and weight. 3) Verify battery health via resistive load test before further tuning. “Efficiency matters” most in motor choice. [Elektroda, Olin Lathrop, post #21658986]
