Running 12AX7 or EC88 Tubes in Parallel for 5-10W DIY Vacuum Tube Amp Build
396 6
  • Parallel tube stages and ignition-coil output transformer concerns
    #1 21659827
    Joe Moschetti
  • 6L6 push-pull output stage recommended
    #2 21659828
    Olin Lathrop
  • 12AX7s in parallel still won’t make power
    #3 21659829
    Joe Moschetti
  • 6L6 or 6V6 push-pull recommended for amp output
    #4 21659830
    Olin Lathrop
  • #5 21659831
    Joe Moschetti
  • AX84.com recommended for DIY tube amp designs
    #6 21659832
    Eduardo Viramontes
  • 12AU7 and 6L6 recommended for audio power amp
    #7 21659833
    DAVID CUTHBERT
The discussion addresses building a 5-10 watt DIY vacuum tube amplifier, focusing on the feasibility of running 12AX7 or ECC88 tubes in parallel to increase output power. The 12AX7 is primarily a low-current preamplifier tube unsuitable for power amplification, while the ECC88 (equivalent to 6DJ8) can deliver about 1 watt in push-pull configuration but is not designed for higher power output. Power tubes like the 6L6 or 6V6 are recommended for achieving 5-10 watts, typically used in push-pull arrangements with output transformers to match speaker impedance and reduce even-order distortion. Paralleling tubes is possible if they are matched types and manufacturers, often aided by cathode degeneration resistors for current sharing. A 12AX7 is generally needed to provide sufficient voltage gain and phase inversion to drive power tubes, as direct drive from low-level sources like CD players is insufficient. Guitar amplifier designs, such as those found on AX84.com, offer practical examples but may require gain adjustments for clean audio use. Overall, fewer tube types simplify sourcing and circuit design, with 6L6 tubes favored for their availability and power capability.
