Where to find durable multimeter probe clips with strong flat metal hooks and springs?
234 9
Where can I buy durable multimeter probe clips with strong spring-loaded metal hooks that stay attached to wires and component leads?
Look for higher-quality Fluke or Hirschmann probe clips rather than the cheap bent-wire types; the Hirschmann versions were described as good quality, hard to knock off, and cheaper at RS than on eBay [#21679567][#21679569] The older AVO-style clips with a flat metal hook and a strong spring were remembered as very positive, but they are not easy to find now [#21679563][#21679567] If you need something for IC work, 3M 923700 clips are available in sizes from 8 to 24 pins and can be used to access pins for test purposes [#21679571]
  • #1 21679562
    Graham Rounce
  • Question about intended use for probe clips
    #2 21679563
    David Ashton
  • #3 21679564
    Graham Rounce
  • #4 21679565
    Rick Curl
  • Croc clip attachments may grip better than bent wires
    #5 21679566
    Graham Rounce
  • Fluke and Hirschmann probe clip recommendations
    #6 21679567
    David Ashton
  • #7 21679568
    Graham Rounce
  • #8 21679569
    David Ashton
  • #9 21679570
    Graham Rounce
  • 3M IC test clips for easy pin access
    #10 21679571
    David Ashton
The discussion focuses on sourcing durable multimeter probe clips featuring strong flat metal hooks with robust springs, as opposed to the commonly found weak bent wire hooks that often fail to maintain grip. Classic clips from AVO multimeters are recalled for their positive grip but are less suitable for delicate IC pins due to risk of shorting. Alternatives suggested include alligator clips available from suppliers like Digi-Key and Pomona grabbers, though these may still lack sufficient spring tension. High-quality clips with two spring wires that firmly grasp wires are recommended, with Hirschmann (Germany) and Fluke cited as manufacturers of reliable, well-made probe clips. Hirschmann clips are noted to be available at competitive prices from RS Components. For IC testing, specialized clips such as 3M's 923700 series, which come in various pin counts and allow easy access to IC pins, are also recommended.
