LG Flatron Monitor Shows Frequency Exceeded 60Hz After Capacitor Replacement
243 7
  • Capacitor replacement did not change monitor frequency
    #1 21661186
    David Taylor
  • Low-ESR capacitors may be required in the supply
    #2 21661187
    Steve Lawson
  • #3 21661188
    Ian Fearn
  • #4 21661189
    John Albers
  • #5 21661190
    Steve Lawson
  • #6 21661191
    John Albers
  • #7 21661192
    Steve Lawson
  • Output-side caps likely need lower ESR replacements
    #8 21661193
    David Taylor
An LG Flatron monitor experienced a power supply failure, prompting capacitor replacement with generic Panasonic capacitors of matching capacitance and voltage ratings (e.g., 1000µF/25V). Post-repair, the monitor displayed a frequency error indicating the refresh rate exceeded 60Hz, reaching approximately 67Hz. The issue is hypothesized to stem from differences in capacitor characteristics beyond capacitance and voltage, specifically the Effective Series Resistance (ESR). Higher ESR in replacement capacitors, especially in switching power supplies, can affect voltage stability and current delivery, potentially causing oscillators within the monitor to operate at incorrect frequencies. The original capacitors lasted about four years under daily use. It is suggested to replace the capacitors with low ESR types to restore proper frequency output. Adjusting the computer's refresh rate to 60Hz is also recommended, as most flat panel monitors are designed to operate at this frequency.
