Is It Legal to Sell Products Based on Modified Punk Console or Combined Pedal Circuits?
1623 10
Can I legally sell synthesizer or pedal products based on modified DIY or copyrighted circuit schematics and datasheet application circuits?
You can usually sell an improved circuit if there is no patent or patent pending on the design, because a copyright on the schematic mainly protects the drawing/distribution of the paper schematic, not the circuit idea itself [#21661369][#21661371] If you are using circuits from IC datasheets, those application circuits are provided so you will use the IC, and using them in your own design was described as having no strong legal or ethical problem [#21661374] Patents on the IC itself do not necessarily prevent you from using that IC in your product; what matters is whether the specific circuit or its use is patented [#21661373] The safest advice was to consult a patent attorney before selling anything commercially [#21661369] Ethically, contacting the original creator and asking permission is the cleanest approach, and in this thread the poster later reported getting that permission and being told to go ahead [#21661377]
  • Legal and ethical questions about modified circuit derivatives
    #1 21661367
    Danalog Barkman
  • #2 21661368
    Stephen Shaffer
  • Copyright does not prevent building a circuit
    #3 21661369
    Earl Albin
  • Copyright on schematic does not cover the circuit itself
    #4 21661370
    Danalog Barkman
  • Copyright limits schematic distribution, not the design
    #5 21661371
    Earl Albin
  • #6 21661372
    Danalog Barkman
  • #7 21661373
    Steve Lawson
  • #8 21661374
    DAVID CUTHBERT
  • #9 21661375
    Danalog Barkman
  • #10 21661376
    Danalog Barkman
  • #11 21661377
    Danalog Barkman
The discussion addresses the legal and ethical considerations of designing and selling analog synthesizers and effects based on modified or combined existing circuits, such as the Punk Console stepped tone generator and power sections derived from various pedal designs and IC application notes. It is generally legal to build circuits from copyrighted schematics for personal use, but commercial use may be restricted if patents exist. Copyright protects the schematic's distribution but not the circuit design itself, while patents protect inventions and improvements. Using IC application circuits from datasheets is typically allowed, as these are intended for design use. Ethical practice includes seeking permission from original creators when modifying and selling derivative products, which was confirmed as acceptable in this case. Consulting patent attorneys is recommended for clarity on intellectual property rights. The discussion highlights common industry practices of circuit adaptation, the distinction between copyright and patent protections, and the importance of professional legal advice to ensure compliance and ethical conduct in electronics product development.
