Protecting 9VDC Circuit from Accidental 28VDC Supply Connection, 5-10mA Current
315 13
How can I protect a 9VDC circuit that normally draws 5–10 mA from accidental connection to a 28VDC supply?
Use a 9V regulator or a crowbar/fuse overvoltage protector; for your low current, a regulator rated for 28V input is the simplest fix. A LM317L or LM78L09/7809 was suggested because the 19V drop at 5–10mA only dissipates about 0.1–0.2W, and with the usual input/output capacitors it will provide a stable 9V output [#21661885][#21661883] If you want true fault protection rather than just regulation, a zener-triggered SCR crowbar with a fuse is the standard approach: the zener turns on the SCR, the output is shorted, and the fuse blows quickly [#21661875] Another option mentioned was a simple shunt regulator using a 9.1V zener and resistor; for about 10mA from 28V, a 1.8k resistor was calculated, with the zener power well below 1.3W [#21661879]
  • #1 21661874
    Charlie Hart
  • Crowbar fuse protection for overvoltage faults
    #2 21661875
    Boi Okken
  • #3 21661876
    Charlie Hart
  • #4 21661877
    Per Zackrisson
  • #5 21661878
    Charlie Hart
  • 1.3 W 9.1 V zener with 1.8 kΩ resistor
    #6 21661879
    Boi Okken
  • #7 21661880
    Mark Harrington
  • Series NPN regulator for 14–28 V to 9.5 V output
    #8 21661881
    Mark Harrington
  • #9 21661882
    Charlie Hart
  • 7809 regulator suggested for 28V to 9V drop
    #10 21661883
    Per Zackrisson
  • #11 21661884
    Mark Harrington
  • Use a 28V-tolerant regulator for 9V protection
    #12 21661885
    Steve Lawson
  • #13 21661886
    Cody Miller
  • Proteus simulation quirks and missing transformer component
    #14 21661887
    Mark Harrington
The discussion addresses protecting a 9VDC circuit, drawing 5-10mA, from accidental connection to a 28VDC supply. Common transient protection methods are insufficient for constant overvoltage scenarios. Recommended solutions include using a fuse combined with a crowbar circuit, which employs a zener diode and an SCR to create a short circuit that blows the fuse rapidly, protecting downstream components. Another approach involves a resistor-zener-transistor regulator circuit to drop 28V to 9V, with detailed calculations for resistor and zener diode ratings to handle the voltage difference and current safely. Voltage regulators such as the LM7809 or LM317L are suggested for stable 9V output from 28V input, given the low current draw and manageable power dissipation. A single NPN transistor regulator circuit capable of operating from 14V to 28V with output near 9.5V is also proposed, with options for higher current using a Darlington array. The discussion includes practical considerations like board space, power dissipation, and component selection. Additionally, circuit design and simulation tools like Proteus Professional are mentioned for schematic creation and testing.
TL;DR: Protect a 9 V, 5–10 mA circuit from accidental 28 V by using a crowbar + fuse or a 9 V regulator; “use a fuse in combination with a ‘crowbar’.” [Elektroda, Boi Okken, post #21661875]
Why it matters: This prevents constant-overvoltage damage when someone plugs the wrong supply into your low‑power board. This FAQ is for engineers and hobbyists asking how to harden 9 V electronics against 28 V hookups.
What’s the simplest way to protect a 9 V circuit from an accidental 28 V supply?
Use a crowbar circuit with a fast fuse. A zener senses overvoltage and triggers an SCR, shorting the input so the fuse opens. This method sacrifices the fuse to save the load and reacts very quickly. It’s compact and ideal when you only need milliamps at 9 V and want robust protection against constant overvoltage, not just transients. “Use a fuse in combination with a ‘crowbar’.” [Elektroda, Boi Okken, post #21661875]
How does a crowbar overvoltage protector actually work?
The input feeds a zener set near your trip threshold. When input rises above the zener voltage, current into the SCR gate latches the SCR on, creating a deliberate short. The short causes the series fuse to blow, disconnecting the hazardous source. The load sees only a brief droop instead of sustained overvoltage. Quote: “...zener diode which activates an SCR.” [Elektroda, Boi Okken, post #21661875]
Can I just regulate 28 V down to 9 V at 5–10 mA?
Yes. A 7809 three‑pin linear regulator with two capacitors gives a clean 9 V. At 10 mA from 28 V, dissipation is about 0.19 W (19 V × 0.01 A), which is easy to handle without a heatsink. This approach is space‑efficient and stable for analog loads drawing 5–10 mA. It also doubles as mild surge filtering when paired with proper input/output capacitors. [Elektroda, Per Zackrisson, post #21661883]
Are LM317L or 78L09 viable when the input could be 28 V?
Yes. LM317L supports about 40 V input and 78L09 about 30 V, fitting a 28 V bus at light load. However, beware that a supply labeled “28 VDC” can exceed that if it’s unregulated. Add input headroom or a protection stage if your bus can overshoot. For very light loads, thermal stress remains low, but input rating still matters. [Elektroda, Steve Lawson, post #21661885]
How do I size a simple 9.1 V zener + resistor limiter from 28 V?
Example: choose a 9.1 V zener (≈1.3 W type). Voltage across the resistor is 28 V − 9.1 V = 18.9 V. For ~10 mA load, R ≈ 18.9 V/0.01 A = 1.89 kΩ. Use the E12 1.8 kΩ value. Current is ≈10.5 mA, and zener power ≈9.1 V × 10.5 mA ≈ 0.096 W, well below 1.3 W. This suits small loads; higher load needs redesign. [Elektroda, Boi Okken, post #21661879]
Is dropping voltage with series diodes a good idea here?
It can work, but it costs board space and wastes power in the diodes. The original poster noted limited space and power, making multiple diodes less attractive. A regulator or crowbar‑plus‑fuse offers cleaner protection and regulation in fewer parts. Consider thermal and tolerance issues if you still pursue diode drops. [Elektroda, Charlie Hart, post #21661878]
I need around 1 A at ~9.5 V from 14–28 V. Any reference circuit?
Yes. A single series NPN regulator stage can deliver about 1 A at 9.35–9.55 V from 14–28 V input. For more current, consider a Darlington pass arrangement. The shared design includes calculations for resistor value, zener current (IZ), output voltage, and output current. This topology scales better than a bare zener-resistor. [Elektroda, Mark Harrington, post #21661881]
How do I calculate parts for the single‑transistor regulator Mark mentioned?
Use the provided sheet methodology: derive the series resistor (R), zener current (IZ), target VOUT, and desired IOUT from input range and pass transistor choice. The design targets 9.35–9.55 V output from 14–28 V, at about 1 A. If you need more current, switch to the Darlington version. Keep the pass device within SOA or add heatsinking. [Elektroda, Mark Harrington, post #21661881]
What’s an SCR, and why use it in overvoltage protection?
An SCR is a latching switch that, once triggered, conducts heavily until current falls below its holding value. In a crowbar, a zener’s overvoltage current drives the SCR gate. The SCR then shorts the input, forcing a fuse to open. This gives rapid, decisive protection against constant overvoltage events on the supply line. [Elektroda, Boi Okken, post #21661875]
Any edge cases I should watch with a “28 VDC” source?
Yes. A supply marked 28 V can run higher if it is unregulated or lightly loaded. This can exceed a regulator’s maximum input rating and defeat simple resistor‑zener limiters. Add input headroom, pre‑regulation, or a crowbar to guard against such excursions. This consideration prevents silent over‑stress of components. [Elektroda, Steve Lawson, post #21661885]
Three‑step: How do I build a basic 9.1 V zener limiter quickly?
  1. Pick a 9.1 V zener, ≥1.3 W rating for margin.
  2. Compute R ≈ (28 V − 9.1 V)/0.01 A ≈ 1.89 kΩ; choose 1.8 kΩ.
  3. Verify dissipation: IZ ≈ 10.5 mA; Pz ≈ 0.096 W, well under 1.3 W. [Elektroda, Boi Okken, post #21661879]
Which EDA tool was used to draw the shared schematics?
Proteus Professional by Labcenter Electronics. The contributor noted it’s strong for PCB design, with some simulator quirks on certain oscillator types and limited transformer models. Despite support frustrations, it offers good value with an annual fee. This context can help you reproduce or modify the posted designs. [Elektroda, Mark Harrington, post #21661887]
