Alternative to TIP3055 NPN Transistor for Early Suzuki CDI Ignition Module?
249 10
What is a suitable replacement transistor for an early Suzuki CDI ignition module when a TIP3055 runs too hot?
No specific alternative transistor was identified; the thread suggests the TIP3055 may be acceptable if it is properly mounted to the heat sink with thermal paste, and excessive heat likely points to another fault [#21662646][#21662650] If the replacement still runs much hotter than a known-good unit, measure the current draw of both units and look for an additional problem such as a ground issue or a bad coil [#21662648][#21662644] The original transistor part number was not known, so no exact drop-in substitute could be confirmed [#21662644][#21662646]
  • TIP3055 runs too hot in CDI module
    #1 21662643
    Nick Jagodinski
  • Shorted ignition coil may be overheating transistor
    #2 21662644
    David Adams
  • #3 21662645
    DAVID CUTHBERT
  • Need circuit diagram and original transistor marking
    #4 21662646
    Frank Bushnell
  • #5 21662647
    Nick Jagodinski
  • #6 21662648
    David Adams
  • #7 21662649
    Sarah Harris
  • #8 21662650
    Steve Lawson
  • #9 21662651
    Nick Jagodinski
  • #10 21662652
    DAVID CUTHBERT
  • #11 21662653
    cyrilgrace Feria
A Suzuki motorcycle forum user seeks an alternative to the TIP3055 NPN transistor used in the CDI ignition module of an early 1983 GS550E 4-cylinder, 4-stroke Suzuki. The TIP3055 replacement transistor runs excessively hot despite using a heat sink, raising concerns about reliability and potential roadside failure. Responses highlight the importance of verifying the original transistor part number, ensuring proper heat sinking with thermal paste, and checking for underlying issues such as faulty ignition coils or incorrect coil polarity that may cause excessive current and overheating. The TIP3055 is a high-power transistor rated at 90W and can normally run hot, but if it is hotter than a known good unit, additional circuit faults or grounding issues may be present. Measuring current draw and comparing it to a good unit is recommended. Clarification is sought on whether the transistor switches the ignition transformer primary or functions as an inverter transistor. Overall, the discussion emphasizes troubleshooting the entire ignition circuit and proper thermal management rather than simply substituting the transistor.
