Multilayer Ceramic Capacitor (MLCC) failure root cause analysis
630 10
Why would one specific 10 uF Y5V MLCC on a PCB start developing increasing leakage current after assembly and storage, while identical capacitors on the same board do not?
The most likely cause is mechanical damage or stress to that specific capacitor or its PCB location, especially from depaneling, board handling, or assembly operations; one reported case traced the problem to PCB cutting/bending, where the cap was not visibly cracked but later absorbed humidity and started leaking [#21663253] [#21663257] If the same capacitor position fails repeatedly, that strongly points to a process-induced stress point rather than ESD [#21663253] [#21663254] Another user found passives were damaged by hand screw installation, and moving the stress source solved the failure [#21663254] A bad capacitor batch is still possible, so swapping in another lot and/or contacting Samsung would be a useful confirmation step [#21663248] [#21663249]
  • Voltage-dependent leakage in damaged Y5V MLCCs
    #1 21663247
    Patrick Walsh
  • Suspected bad capacitor batch causing leakage
    #2 21663248
    stephen Van Buskirk
  • #3 21663249
    Steve Lawson
  • #4 21663250
    Kevin Parmenter
  • Voltage, temperature, and soldering stress on MLCCs
    #5 21663251
    Mark Harrington
  • Samsung capacitor failures common in switch-mode supplies
    #6 21663252
    Mark Harrington
  • Depaneling and board handling as likely cause
    #7 21663253
    Gary Crowell
  • Mechanical stress from assembly likely cracked the capacitor
    #8 21663254
    Todd Hayden
  • #9 21663255
    Radek Susina
  • #10 21663256
    Matt Alizadeh
  • #11 21663257
    Radek Susina
A consumer product experienced a sudden 4% failure rate of a specific 10 µF Y5V dielectric MLCC capacitor manufactured by Samsung, exhibiting severe leakage currents from 0.1 mA to 4 mA. Despite identical capacitors on the board, only one failed, suggesting localized damage possibly during or after PCBA or final assembly. Poor ESD control was noted but deemed unlikely as the root cause. Potential causes discussed include microcracks from mechanical or thermal stress, soldering temperature issues especially with unleaded solder, and operating voltage margins being too tight. Testing recommendations included ESR and frequency response analysis to gather diagnostic data for the supplier. Mechanical damage during assembly processes such as hand screw installation or PCB depaneling was highlighted as a probable cause, with one case identifying PCB bending during cutting as a failure source leading to moisture absorption and leakage increase over time. Solutions involved changing capacitor batches, improving mechanical handling, adjusting PCB panel design to include bridges to reduce bending stress, and consulting the manufacturer for support.
