Super Bright RGB LED for Moving Head: 120,000-150,000 Lux, Max 8x8cm, ~$400
219 9
Can I build an RGB moving-head light with a maximum 8×8 cm LED package that produces 120,000–150,000 lux at 1 m with a 25° beam for about $400?
A single RGB LED in an 8×8 cm package will not realistically deliver 120,000–150,000 lux at 1 m; you need to think in lumens, beam angle, and heat dissipation rather than just LED size [#21671910] For a 25° beam at 1 m, the lit area is about 0.58 m², so 120,000 lux needs roughly 71,000 lumens, and even 150,000 lux works out to about 22,340 lumens after the beam-angle correction [#21671913][#21671915] The strongest LEDs mentioned are only about 740 lumens each, so reaching that output with LEDs would require a very large array and would generate extreme heat and current demand [#21671913] A metal-halide lamp such as the OSRAM SIRIUS HRI was suggested as a more realistic bright source, but it will get quite hot and needs cooling [#21671914][#21671915]
  • #2 21671910
    John Schmitz
  • #3 21671911
    Daan do not prefeur to sa
  • #4 21671912
  • Suggesting an Osram Sirius HRI metal-halide lamp
    #5 21671908
  • Lumens and thermal limits make target impractical
    #6 21671913
    John Schmitz
  • #7 21671914
  • #8 21671915
    John Schmitz
  • #9 21671916
  • #10 21671917
The discussion focuses on sourcing a super bright RGB LED suitable for a moving head light design, targeting an intensity of 120,000 to 150,000 lux at 1 meter with a maximum LED size of 8x8 cm and a budget around $400. Achieving such high lux levels requires extremely high luminous flux; for example, a 25° beam angle at 1 meter corresponds to a surface area of approximately 0.58 m², necessitating around 70,000 lumens to reach 120,000 lux. Current high-power LEDs, such as Cree U2 (5mm x 5mm), produce about 740 lumens each, implying the need for large arrays (e.g., 16x16) to meet the luminous output, which introduces significant heat dissipation challenges (up to 1.7 kW and over 500 A current). Metal halide lamps like the OSRAM Sirius HRI 330W can achieve around 100,000 lux at 1 meter with a 25° beam but generate substantial heat requiring active cooling. The feasibility of passive cooling for such lamps is questioned. The discussion also notes the difficulty in finding compact (≤8x8 cm) light sources that deliver the required intensity without excessive heat. Lens optics with variable beam angles (0° to 75°) are considered to focus the light and increase lux. The user is open to using RGB LEDs or applying color filters to white LEDs if RGB options are unavailable within budget and size constraints.
