How to Make a Bicycle Generator That Only Powers a DVD Player and Projector While Pedaling
312 6
  • Pedal-activated power cutoff for projector and DVD player
    #1 21663358
    Daniel Wcislo
  • Capacitor-backed projector power to avoid battery cycling
    #2 21663359
    Steve Lawson
  • #3 21663360
    Daniel Wcislo
  • Encourages asking specific questions in a new thread
    #4 21663361
    Steve Lawson
  • Relay-controlled battery isolation for pedal-powered load switching
    #5 21663362
    DAVID CUTHBERT
  • #6 21663363
    Sarah Harris
  • Automotive alternator and inverter bike generator setup
    #7 21663364
    Chuck Sydlo
A mechanical engineer seeks to build a bicycle-powered generator system to run a pico projector and portable DVD player only while pedaling or for a short time afterward, to prevent battery drain and align with the artistic concept. Discussion highlights include the use of pre-packaged bike DC generator systems with integrated battery management to avoid deep discharge, though typical use cases may differ from this application. The pico projector can store videos internally or on an SD card, potentially eliminating the need for a DVD player. Challenges include enabling automatic video playback or kiosk mode without manual intervention. A simple relay and diode circuit is proposed to connect the battery to the projector only when the generator is active, though relay pull-in voltage and battery discharge at low speeds are concerns. Alternative suggestions include using a small automotive alternator with built-in voltage regulation, coupled with a battery and a pure sine wave inverter matched to the load requirements, ensuring inverter overload protection. Considerations involve matching voltage ratings, load calculations with safety margins, and mechanical adaptation for belt drive from the bicycle axle.
