How to Build Sequential Lamp Tree for Treadmill Motor Bicycle Generator Classroom Project
327 8
  • Seeking a frugal sequential lamp tree design
    #1 21678959
    Ryan Northup
  • Suggesting zener-triggered transistor lamp stages
    #2 21678960
    David Ashton
  • #3 21678961
    Ryan Northup
  • Use rectified generator output to drive analog display
    #4 21678962
    Rick Curl
  • #5 21678963
    Elizabeth Simon
  • Arduino Uno project links for related builds
    #6 21678964
    John Umolu
  • #7 21678965
    matt simons
  • #8 21678966
    Beazy
  • #9 21678967
    Timothy Lyall
A career and technical high school project involves salvaging a treadmill DC motor, originally rated at 95 volts but currently producing approximately 18 volts, coupled to a bicycle to generate electricity. The goal is to create a sequential lamp tree that lights lamps progressively as voltage increases, simulating a carnival game for students. Suggested solutions include using Zener diodes with resistors and power transistors to activate lamps at different voltage thresholds, enabling sequential lighting. Alternative approaches recommend not powering lamps directly from the generator but instead applying a load to the generator, rectifying the output if AC, and feeding it into an analog bar graph display or a large analog panel meter for a simple visual voltage indicator. Using a voltmeter display, digital or analog, with a resistor divider to scale voltage is also proposed. Additional resources on Arduino Uno R3 projects were shared but are not directly related to the lamp tree concept.
