Best USB or Bluetooth Switch Modules for Android-Controlled Light Project
324 6
  • #1 21663652
    Ann Lee Watson
  • Embedded webserver as a wireless light switch solution
    #2 21663653
    Pieter Kruger
  • IOIO board with 230 V 16 A relay proposed
    #3 21663654
    Ann Lee Watson
  • IOIO board with transistor-driven 230V relay
    #4 21663655
    Pieter Kruger
  • Concerns about $5 Bluetooth reliability and cooling
    #5 21663656
    Ann Lee Watson
  • Clarifying reliability, heat, and application details
    #6 21663657
    Pieter Kruger
  • Wired plugs preferred for year-long reliability in heat
    #7 21663658
    Ann Lee Watson
The discussion focuses on selecting suitable switch modules for an Android-controlled light project. The proposed system involves an Android app sending commands to a relay to control a 230V/16A light. Recommended solutions include using a microcontroller board such as the IOIO board combined with a relay and appropriate connectors. Key considerations include the need for an external power supply to drive the relay via a transistor or MOSFET, as the Android device alone may not supply sufficient current. Bluetooth connectivity via a mini USB adapter was considered but raised concerns about reliability for continuous operation. Thermal management was discussed, with the conclusion that a fan is likely unnecessary even for buried outdoor installations, though protective casing suitable for high ambient temperatures (e.g., 40°C in southern Spain) is advised. Alternatives like embedded webservers with Wi-Fi control were also mentioned for more generic, cable-free operation. The IOIO board was favored for its size, cost, and ease of use, with the upcoming IOIO v2 noted. The total estimated system cost is around 200 Euros, including the Android device (e.g., Samsung Galaxy Y or HTC Desire S), relay, IOIO board, and Bluetooth adapter.
