[Solved] Remote lighting control module with 230V switch in the box - how to choose?
CiekawyŚwiata 732 4
  • Wireless relay modules for two independent circuits
    #1 21417100
    CiekawyŚwiata
    Rate: 15
    I have a switch in a wall box in which I have a 230V power supply. Under this switch I would like to hide a module which will control wirelessly two modules which will switch independently two different lighting circuits. Unfortunately I do not have the possibility of controlling directly from this box. I don't know if there is such a solution at all, although there probably is :) How it is supposed to work (because I don't know if what I wrote above is clear) in the box with the switch (it can be a mono or bi-stable switch) there is supposed to be module A which will remotely switch on/off modules B and C after pressing the left or right button respectively. It cannot be a whole wireless switch because it is important that it stays what it is so that the switches look identical throughout the room. Both in the box with the switch and in the places of modules B and C there is an N and L wire of the 230V installation.
    All modules will be in the same room 2-3m from each other
  • #3 21419294
    CiekawyŚwiata
    Rate: 15
    >>21417135 I think you have misunderstood.... It's not about remotely controlling a switch just that the switch remotely controls another device/relay. It has to be three separate modules in which one module can wirelessly control the other two.
    techlock
    Help: 217
    Rate: 525
    This can be implemented on such modules.
    You set so-called scenes in the control application.
    E.g. Smart Life app, function When device status changes.
    You set Switch B to change its status if the status of Switch A changes. Similarly on switch C.
    You choose the application according to your needs and the Smart switches that work with it.
    There are many of these on the market.
  • #5 21419441
    CiekawyŚwiata
    Rate: 15
    Thanks for your help
