How can I convert a value in millimeters to mils (thousandths of an inch)?
To convert millimeters to mils, multiply the millimeter value by 39.3700787, because 1 mm = 39.3700787 mils [#21663981] For example, 328 mm becomes 12,913.3858 mils [#21663981] You can also use Google’s built-in calculator by typing a conversion like `328 mm = mils` into the search box [#21663981] If you want an online tool instead, convertunits.com and WolframAlpha were suggested as convenient mm-to-mils converters [#21663980][#21663984]
1 millimeter = 39.3700787 mils (thousandth of an inch).
The simplest way to convert parameters is to use Google’s built-in calculator function. Simply enter the calculation you’d like done into the Google search box.
For example, just enter "328 mm = mils" and you'll get the answer "328 millimeters = 12 913.3858 mils" right below the search box.
wolframalpha dot com also has a good conversion calculator. Just type in "millimeters to mils" and a box will appear where you can type in your millimeter values.
The discussion addresses the conversion of millimeters (mm) to mils (thousandths of an inch). The exact conversion factor is 1 millimeter = 39.3700787 mils. Several practical methods for conversion are recommended, including using online calculators such as Google’s built-in calculator by typing queries like "328 mm = mils," the website convertunits.com, and Wolfram Alpha’s conversion tool. Additionally, a free software program named Convert is suggested for repeated use on computers. A cautionary note highlights that American Wire Gauge (AWG) wire sizes are based on circular mils, not square mils, with a reference link provided for clarification. The discussion emphasizes the availability of digital tools and software to facilitate accurate and efficient unit conversions in electronics and engineering contexts. AI summary based on the discussion. May contain errors.
