How to Identify Thevenin vs Norton Equivalent Boxes Using Simple Circuit Tests
204 7
  • Simple test to distinguish Thevenin and Norton boxes
    #1 21664176
    sajjad Asefi
  • #2 21664177
    David Adams
  • #3 21664178
    sajjad Asefi
  • #4 21664179
    David Adams
  • #5 21664180
    Steve Lawson
  • #6 21664181
    David Adams
  • #7 21664182
    Steve Lawson
  • #8 21664183
    sajjad Asefi
The discussion addresses the challenge of distinguishing between Thevenin and Norton equivalent circuits enclosed in opaque boxes using simple circuit tests. Thevenin equivalents consist of a voltage source in series with a resistor, while Norton equivalents have a current source in parallel with a resistor. It is emphasized that, by definition, these equivalent circuits produce identical voltage-current characteristics at their terminals, making it impossible to determine the internal configuration solely through external measurements or simple load tests. One response notes that if the boxes represent physical, non-ideal sources, subtle differences might be observed by stressing the system beyond ideal conditions, but this approach is unreliable and not definitive. Overall, the consensus is that no straightforward circuit test can reveal whether a box contains a Thevenin or Norton equivalent, as their terminal behavior is indistinguishable.
