Modifying LED Schematic to Use 20mA LEDs Instead of 10mA for Star Trek Panel
612 30
How can I change a 5 V LED flashing circuit so it safely drives 20 mA LEDs instead of 10 mA LEDs?
You don't need to redesign the blinker; the LED current is set by the series resistor, so you just change that resistor to suit the 20 mA LEDs [#21664253][#21664255] Use R = (V - Vf) / I, where V is the supply/output voltage, Vf is the LED forward voltage, and I is the current you want; for a 5 V circuit you should use the LED's datasheet Vf and its max continuous current rather than assuming the full 5 V is across the resistor [#21664255] A "10 mA LED" or "20 mA LED" is really just a LED with a maximum continuous current rating, so you can run a 20 mA LED at a lower current if you want less brightness and less power [#21664255] If you want to be conservative, a larger resistor such as 500 Ω will make it dimmer, while 250 Ω is the lower-resistance option discussed for higher current [#21664253] If you don't have a datasheet, use a small test circuit with an ammeter and variable resistor to measure the LED's forward voltage at the current you want, then choose a fixed resistor from that [#21664255]
  • Use 20 mA LEDs by adjusting the current limit
    #1 21664252
    Zack MacKeigan
  • Reduce LED resistor to 500 Ω or 250 Ω
    #2 21664253
    Mike P OKeeffe
  • Asking resistor values for 20mA LEDs at 5V
    #3 21664254
    Zack MacKeigan
  • LED current set by series resistor and Vf
    #4 21664255
    Steve Lawson
  • Microcontroller with reseeded RNG for varied light patterns
    #5 21664256
    Steve Lawson
  • Confirming resistor values for 20mA LEDs
    #6 21664257
    Zack MacKeigan
  • #7 21664258
    Zack MacKeigan
  • PIC16F877 or 16F88 with 74LS373 outputs
    #8 21664259
    Mark Harrington
  • #9 21664260
    Zack MacKeigan
  • Recommend PICkit 2/3 and MikroElektronika IDE
    #10 21664261
    Steve Lawson
  • #11 21664262
    Steve Lawson
  • #12 21664263
    madhurika Shrivastava
  • Microchip PICs support in-circuit programming
    #13 21664264
    Mark Harrington
  • PIC alternatives with built-in bootloaders suggested
    #14 21664265
    Steve Lawson
  • #15 21664266
    Zack MacKeigan
  • PICaxe starter kit and simple LED blink code
    #16 21664267
    Steve Lawson
  • Switching to an Arduino kit for flexibility
    #17 21664268
    Zack MacKeigan
  • #18 21664269
    Steve Lawson
  • PICAXE recommended as easiest microcontroller starter
    #19 21664270
    Frank Bushnell
  • PIC Basic easier than C for beginners
    #20 21664271
    Mark Harrington
  • #21 21664272
    Zack MacKeigan
  • #22 21664273
    Mark Harrington
  • C can be used at a beginner level without pointers
    #23 21664274
    Steve Lawson
  • #24 21664275
    Steve Lawson
  • #25 21664276
    Steve Lawson
  • #26 21664277
    Steve Lawson
  • Assignment vs equality operator confusion in C and Basic
    #27 21664278
    Mark Harrington
  • #28 21664279
    Per Zackrisson
  • Breadboard copy lights up but blinks randomly
    #29 21664280
    Zack MacKeigan
  • #30 21664281
    Steve Lawson
The discussion centers on modifying a simple LED driver schematic designed for 10mA LEDs to accommodate 20mA LEDs for a Star Trek: TOS style panel project. The key technical advice is to adjust the current-limiting resistor value according to Ohm's law, considering the LED forward voltage and desired current. For a 5V supply and 20mA LEDs with a forward voltage around 3.2-3.4V, resistor values between 250Ω and 500Ω are recommended to safely limit current and control brightness. The original schematic used a 1kΩ resistor for 10mA LEDs, which results in about 5mA current; lowering the resistor value increases current accordingly. The conversation also explores alternatives to the CMOS binary counter/divider circuit, suggesting microcontroller-based solutions like Arduino or PICAXE for more flexible and realistic LED flashing patterns using pseudo-random number generation. PIC microcontrollers (e.g., PIC16F877, PIC16F88) and development tools such as MikroElectronica IDE and Microchip MPLAB are discussed as cost-effective alternatives to Arduino, though Arduino is favored for beginner-friendly support and ease of use. Programming languages mentioned include BASIC (for PICAXE) and simplified C (for Arduino). The user eventually opts to switch to an Arduino kit after difficulties with the original board. Additional resources include online tutorials and blogs on LED driving techniques.
TL;DR: At 5 V, a 1 kΩ resistor gives ~5 mA; “All you have to change is the resistor value.” Choose ~250–500 Ω for 20 mA LEDs, using R = (V − Vf) / I. [Elektroda, Mike P OKeeffe, post #21664253]
Why it matters: This FAQ helps beginners convert 10 mA LED blinkers to 20 mA parts safely for Star Trek‑style panels.
How do I convert a 10 mA LED schematic to use 20 mA LEDs at 5 V?
Change the series resistor. Use R = (V − Vf) / I. With 5 V supply and white LEDs, target ~250 Ω for 20 mA, or ~500 Ω for dimmer output. Stay at or below the LED’s continuous current rating. “All you have to change is the resistor value.” [Elektroda, Mike P OKeeffe, post #21664253]
How many 20 mA white LEDs can I run from one 5 V output?
With white LEDs at ~3.2–3.4 V Vf, 5 V usually supports one LED plus a resistor per output. For series strings, sum Vf and ensure the total stays below the supply; then compute R from the remaining voltage. Use the highest expected Vf for safety. [Elektroda, Steve Lawson, post #21664255]
What does “20 mA LED” actually mean?
It’s the LED’s maximum continuous current rating, not a built‑in draw. The actual current depends on how you drive it. Set the current with a series resistor or a current regulator per R = (V − Vf) / I. [Elektroda, Steve Lawson, post #21664255]
How do I pick a resistor when LED forward voltage varies?
Use the worst‑case (highest) Vf from the datasheet in R = (V − Vf) / I. That ensures current stays at or under your target across part and temperature variations. Add margin if no datasheet is available. [Elektroda, Steve Lawson, post #21664255]
Is it safer to run 20 mA LEDs below 20 mA for this blinker?
Yes. Driving below maximum reduces brightness, heat, and stress. For a 5 V CMOS blinker, try ~500 Ω for gentler current and compare brightness. You can experiment, but do not exceed the LED’s limit. [Elektroda, Mike P OKeeffe, post #21664253]
Can I share one resistor across two LEDs?
Only if they’re in series and the summed Vf is under the supply. Then compute R from the remaining voltage: R = (V − ΣVf) / I. Avoid parallel LEDs on one resistor; current will not split evenly. [Elektroda, Steve Lawson, post #21664255]
What is forward voltage (Vf) on an LED?
Vf is the voltage drop across the LED when it conducts. It depends on color, current, age, lot, and temperature. Use the highest expected Vf to size your resistor so current stays within spec. [Elektroda, Steve Lawson, post #21664255]
Should I use a microcontroller (Arduino) instead of a CMOS counter for random blinking?
A microcontroller gives richer, less repetitive patterns using a pseudo‑random number generator. You can even reseed on motion or sound for interactive effects. This avoids obvious repeating sequences. [Elektroda, Steve Lawson, post #21664256]
Are there cheaper beginner‑friendly alternatives to Arduino?
Yes. PICAXE chips program in BASIC and are very beginner‑friendly. You mainly need the USB programming cable (about £12), a breadboard, a few resistors, and the free software. [Elektroda, Frank Bushnell, post #21664270]
What hardware do I need to program a bare PIC microcontroller?
Get a programmer such as a PICkit 2 or 3. Expect around $40–$50, but it serves future PIC projects. You can also explore free IDE options from MikroElektronika or Microchip. [Elektroda, Steve Lawson, post #21664261]
How can I measure unknown LED Vf and set current without a datasheet?
Build a quick test: supply, ammeter, variable resistor, and LED socket. Adjust to your target current, read Vf, then compute a fixed resistor using R = (V − Vf) / I. Add margin for variation. [Elektroda, Steve Lawson, post #21664255]
What is a CMOS binary counter/divider doing in this circuit?
It steps outputs sequentially from a clock, presenting near‑supply voltage at each Q pin. Each active output drives its LED branch through a current‑limiting resistor, creating blinking channels. [Elektroda, Mike P OKeeffe, post #21664253]
How do I compute a resistor for a 3.2–3.4 V white LED on 5 V?
Use the highest Vf and your desired current. Example: for 10 mA, R ≈ (5 − 3.4) / 0.01 = 160 Ω. For 20 mA, R ≈ 80 Ω, but consider using higher resistance for longevity and brightness control. [Elektroda, Steve Lawson, post #21664255]
Quick how‑to: set LED current correctly in three steps
  1. Note supply V and LED’s highest Vf.
  2. Choose target current (≤ LED’s max).
  3. Compute R = (V − Vf) / I and pick the nearest standard value. [Elektroda, Steve Lawson, post #21664255]
Why did my build light but not blink randomly?
Randomness from simple counters can look repetitive. A microcontroller can produce varied patterns and sudden changes. “Use a pseudo random number generator…and reseed with sensors.” [Elektroda, Steve Lawson, post #21664256]
What’s a practical starting point if I’m nervous about capacitors and timing parts?
Prototype on a solderless breadboard, verify each channel lights, then tune resistors for brightness. If patterns feel monotone, migrate the logic to an Arduino and reuse the LEDs and resistors. [Elektroda, Zack MacKeigan, post #21664280]
