IC Socket or Adapter Options for 4mm 10-Pin ChipScale Package Soldering?
372 12
How can I solder a 4 mm, 10-pin leadless IC package, and is there an adapter or socket for it?
You can solder that leadless 4 mm part by hand, but the thread recommends using an adapter board rather than a socket, with SchmartBoard being the suggested solution [#21664468][#21664471] The part was identified as a leadless UDFN package, and the specific SchmartBoard adapter mentioned was 202-0016-01, using the LFCSP20 footprint with 0.5 mm pitch and 2.794 mm square pads; the extra pins would simply remain unconnected [#21664468][#21664471] For soldering, one reply recommends the standard SchmartBoard method plus a chisel-tipped soldering iron, which was said to work well for SMD chips [#21664467] Another option is hot air, provided you stay within the IC’s datasheet temperature limits [#21664470] The ground/thermal pad underneath may be optional depending on the application, but if you use the adapter, verify with a multimeter afterward that no pins are shorted together or to the pad [#21664471]
  • No socket option for 4 mm 10-pin chip-scale ICs
    #1 21664460
    Cart McCormick
  • #2 21664461
    Julio Flores
  • #3 21664462
    Mike P OKeeffe
  • #4 21664463
    Jiajun Chen
  • Microchip MTD6506T BLDC driver needs adapter
    #5 21664464
    Cart McCormick
  • Question about solder paste masking on tracks
    #6 21664465
    Cart McCormick
  • #7 21664466
    Cart McCormick
  • #8 21664467
    Steve Lawson
  • Solder mask prevents solder wetting on bare PCB
    #10 21664469
    Jiajun Chen
  • #11 21664470
    Muazu Musa
  • Schmartboard LFCSP20 fits 0.5 mm UDFN with caution
    #12 21664471
    Mike P OKeeffe
  • Heatsink compound suggested for thermal pad contact
    #13 21664472
    Steve Lawson
The discussion addresses the challenge of soldering a very small 4mm 10-pin leadless IC, specifically the Microchip MTD6506T BLDC 3-phase sensorless motor driver in a UDFN package without protruding leads. The original poster seeks an IC socket or adapter to simplify soldering. Responses clarify that hand soldering such packages is possible but requires careful technique and tools like hot air rework stations and solder paste. Several helpful resources and videos demonstrate soldering methods for QFN/UDFN packages, including the use of solder mask to prevent shorts and the application of solder paste on pads only. The SchmartBoard brand offers specialized adapter boards (e.g., part numbers 204-0022-01 and 202-0016-01) designed for chip-scale packages, facilitating hand soldering by providing breakout pads and proper pitch. Concerns about the thermal ground pad under the IC are discussed, with suggestions to connect it for heat dissipation or use a small amount of heatsink compound to aid thermal conduction and mechanical stability. Overall, the recommended solution is to use a SchmartBoard adapter tailored for the package, combined with careful hand soldering techniques demonstrated in linked instructional videos.
TL;DR: For a 4 mm, 10‑pin UDFN like Microchip’s MTD6506T, a 0.5 mm‑pitch SchmartBoard adapter works, and “They’re really good videos.” [Elektroda, Mike P OKeeffe, post #21664471]
Why it matters: This FAQ helps students and hobbyists hand‑solder tiny leadless chips or pick a simple adapter without expensive tools.
What package is the MTD6506T and why is it tricky to solder?
It’s a small, leadless UDFN. There are no protruding leads to grab with an iron, so alignment and paste control matter more than usual. Hand techniques and adapters can bridge the gap when you lack hot air tools. [Elektroda, Steve Lawson, post #21664468]
Is there a plug‑in socket or adapter I can buy for this 10‑pin chip?
Use a breakout adapter. The SchmartBoard 202‑0016‑01 (LFCSP20) matches the 0.5 mm pitch; leave extra pins unconnected. Its pad is about 2.794 mm², suitable for this footprint. “They’re really good videos,” notes one poster about the method. [Elektroda, Mike P OKeeffe, post #21664471]
Do I need to solder the exposed ground pad under the UDFN?
It is primarily for thermal relief. The datasheet indicates it can be connected to improve heat dissipation, but simple builds may omit it. Evaluate thermal load before skipping it. [Elektroda, Mike P OKeeffe, post #21664471]
How do I hand‑solder a UDFN without a hot‑air station?
Use flux and a chisel‑tip iron; drag‑solder the edges while holding alignment. The linked video’s first section shows tips for iron‑only work. Many users succeed with this budget method.
  1. Flux pads, place chip, tack one corner.
  2. Drag‑solder pins with minimal solder.
  3. Wick bridges, clean, inspect. [Elektroda, Steve Lawson, post #21664468]
Why doesn’t spreading solder paste across the tracks short everything?
The board’s solder mask covers everything except pads. Molten solder wets pads but has poor wetting on mask, so it pulls back and separates during heating. That’s why paste can be applied broadly in demos. [Elektroda, Jiajun Chen, post #21664469]
What tools work on a student budget for this job?
Combine a chisel‑tip iron, flux, tweezers, magnification, and patience. A SchmartBoard adapter helps convert to larger pads. One poster endorses the chisel‑tip drag method: “it works great.” [Elektroda, Steve Lawson, post #21664467]
How do I confirm I didn’t create shorts after soldering?
Probe each adjacent pin pair with a multimeter in continuity mode, then check pins to the exposed pad. Only power the circuit after a clean test. This simple step prevents costly failures. [Elektroda, Mike P OKeeffe, post #21664471]
Can I use a tiny dab of thermal compound under the chip to help with placement?
A small amount can help hold the chip and provide a thermal path. Keep it away from electrical pads to avoid contamination. Apply sparingly and verify alignment before soldering. [Elektroda, Steve Lawson, post #21664472]
What if my PCB has no solder mask—will paste definitely bridge?
Bridging risk is higher on bare boards. Use a breakout adapter like a SchmartBoard to gain proper mask‑defined pads and easier spacing to hand‑solder. [Elektroda, Jiajun Chen, post #21664469]
Can I hot‑air solder this tiny package if I’m careful?
Yes. A hot‑air blower can work if you respect the IC’s thermal limits from the datasheet. Preheat evenly, limit dwell time, and avoid lifting parts with excessive airflow. [Elektroda, Muazu Musa, post #21664470]
What does UDFN or LFCSP actually mean?
UDFN/LFCSP are very small leadless chip packages with contacts on the underside edges and often an exposed thermal pad. They need precise alignment and reflow or careful hand techniques. [Elektroda, Steve Lawson, post #21664468]
Any adapter caveats I should know before ordering?
One poster flagged limited diagram detail and wondered if traces meet under the pad on some adapters. Inspect the board photos or drawings to ensure pad isolation before soldering. [Elektroda, Mike P OKeeffe, post #21664471]
What’s a safe first‑power‑up checklist after assembly?
Visually inspect under magnification, confirm no bridges, and verify supply‑pin resistance to ground. Power with a current‑limited bench supply first. This catches faults early. [Elektroda, Mike P OKeeffe, post #21664471]
Where can I see the recommended soldering techniques in action?
The thread links videos showing UDFN handling and iron‑only drag‑soldering tips. Watch the first section for alignment, fluxing, and solder control. [Elektroda, Steve Lawson, post #21664468]
What’s the pitch and why does it matter for adapters?
This case references a 0.5 mm pitch, which dictates adapter choice and soldering tip size. Matching pitch avoids misalignment and bridging on breakouts. [Elektroda, Mike P OKeeffe, post #21664471]
Edge case: what failure happens most when beginners try this?
The most common failure is hidden shorts to the exposed pad or between fine‑pitch pins. Always meter for shorts before applying power to protect the IC. [Elektroda, Mike P OKeeffe, post #21664471]
