How to Program M2732 24-Pin EEPROM for SOMET Jacquard via PC and Compatible Software
372 6
  • #1 21664901
    Shinzkue Nakamora
  • Universal programmer needed for M2732 data transfer
    #2 21664902
    Steve Lawson
  • #3 21664903
    gurpreet Bhui
  • M2732 is likely a UV-erasable EPROM
    #4 21664904
    Steve Lawson
  • #5 21664905
    Steve Lawson
  • #6 21664906
    Shinzkue Nakamora
  • Use an MCU or universal programmer to read EPROM
    #7 21664907
    Steve Lawson
The M2732 is a 24-pin EPROM (not EEPROM) with 32Kbit capacity (4,096 x 8 bits), commonly used in SOMET Jacquard weaving machines for textile pattern storage. It is a UV-erasable, electrically programmable ROM requiring a 5V supply and has an access time of approximately 200 ns. Programming or reading this chip directly via PC using RS232 is not straightforward. A universal programmer, such as the USB TL866A, can program the chip if the data file is available. However, interfacing the M2732 to a PC for reading data typically involves using a microcontroller or microprocessor with an RS232 interface, employing a level shifter like the MAX232 to convert voltage levels. The data can then be transmitted serially to the PC and captured using terminal software (e.g., Hercules). Programming software compatible with the M2732 depends on the data format and may require custom editors for textile pattern code. Erasing the EPROM requires a UV eraser or a germicidal UV lamp, with caution due to harmful UV exposure. No direct RS232 interface schematic was provided, but the approach involves MCU-based address/data multiplexing and serial communication.
