RS232 Relay Board Closes Then Opens Instantly With 12V Pump and Battery Setup
300 12
Why do my RS232-controlled relays drop out immediately when switching a 12V pump from a battery, even though the pump runs normally once started?
The most likely cause is the pump’s startup inrush current pulling the battery voltage down enough to make the relay coil or controller drop out, or tripping an overload cutout set too close to the pump’s starting current [#21664932][#21664939] Power the relay board from a separate stable 12V supply, then measure the actual coil voltage while switching and test a failing relay directly at its rated voltage [#21664933][#21664936] Check battery condition and internal resistance, because amp-hour capacity alone is not the key issue; weak batteries, loose contacts, or corrosion can make the drop-out intermittent [#21664932][#21664937] Also make sure flyback diodes are fitted across the relay coils so back-EMF does not upset the driver circuitry, and verify the logic supply is well decoupled and stable [#21664936] The thread later reported large voltage spikes on the pump circuit and repeated retries before startup, which fits a noise/surge problem rather than normal running current [#21664938][#21664940]
  • Battery voltage sag causing relay dropout
    #1 21664931
    Steven Furick
  • Motor startup current may drop relay coil voltage
    #2 21664932
    Frank Bushnell
  • #3 21664933
    JAWED MATEEN
  • Battery capacity and pump inrush current suspected
    #4 21664934
    Sujin Sreedharan
  • Relay still drops out despite regulated supply
    #5 21664935
    Steven Furick
  • Check relay coil voltage, flyback diodes, and RS232 levels
    #6 21664936
    Steve Lawson
  • #7 21664937
    Steve Lawson
  • Inductive pump spikes likely upsetting relay logic
    #8 21664938
    Steven Furick
  • Overcurrent cutout may be tripping at pump startup
    #9 21664939
    Frank Bushnell
  • #10 21664940
    Steven Furick
  • #11 21664941
    Steven Furick
  • #12 21664942
    Steven Furick
  • Noise, grounding, and isolation recommendations for RS232 relay boards
    #13 21664943
    Mark Harrington
A relay control board operating via RS232 serial communication is used to switch a 12V pump powered by a 12V battery. The relay, rated for 5A, frequently opens immediately after closing, preventing the pump from starting properly. The pump's running current is under 2.1A, but startup inrush current is suspected to be much higher, causing voltage drops and relay dropout. Attempts to mitigate the issue included adding a 2-ohm resistor in series with the pump and parallel capacitors for voltage spike suppression. The relay board was initially powered from the battery but later switched to a regulated 12V supply; however, the problem persisted. The battery is a large capacity 12V unit from an emergency jump starter, showing about 13V at rest. Voltage spikes up to 95V and negative spikes around -200V were observed on the pump circuit, indicating significant inductive kickback. Current measurements via a 1-ohm resistor suggest peak currents up to 11A during startup, higher than the relay rating. Suggestions include powering the relay coil from a separate stable source, verifying relay coil voltage and duration, ensuring flyback diodes are installed across relay coils to protect driver circuitry, checking for loose connections or corrosion, and assessing battery internal resistance and condition. Additional recommendations involve minimizing wiring length to reduce noise, using opto-isolators on RS232 ports, implementing error correction in serial communication, and considering transistor or MOSFET drivers for relay control. The relay board manufacturer confirmed no built-in overvoltage or overcurrent protection, and voltage spikes from inductive loads may interfere with controller logic. The issue likely stems from voltage dips and inductive spikes during pump startup causing relay dropout and communication disruption.
TL;DR: RS232 relay “chatter” here is caused by motor inrush and inductive spikes disturbing control power/logic—“it took 6 or 7 tries before the pump finally started up” (a measured stat). [Elektroda, Steven Furick, post #21664940]
Why it matters: This FAQ helps makers and technicians fix 12 V pump/relay dropouts in PC- or Bluetooth-controlled systems.
Why does my relay close and instantly open with a 12 V pump?
DC motors draw high inrush current at start. The resulting voltage sag and inductive noise can drop the relay coil below its hold voltage, so it releases. If the battery is weak or wiring adds resistance, the sag worsens and the controller may glitch. “An electric motor draws a much higher current than normal when it is starting up.” Measure supply at the relay coil during start to confirm. [Elektroda, Frank Bushnell, post #21664932]
How do I confirm the battery is causing the dropout?
Watch battery voltage during start with a scope or fast DMM. A sharp dip indicates high internal resistance or poor connections. Old or undercharged batteries sag more. If possible, power the relay/control electronics from an independent regulated supply and repeat the test to isolate the load from logic. If the dropout vanishes, the shared supply path was the trigger. [Elektroda, Frank Bushnell, post #21664932]
What inrush current should I expect from a small 12 V pump?
Expect several times the run current. In this thread, a 2.1 A pump showed a peak near 11 A with a 1 Ω series shunt. That surge can momentarily pull the supply or wiring low, unlatching a 5 A relay and upsetting logic. Plan wiring, fusing, and relay contact ratings with that peak in mind. [Elektroda, Steven Furick, post #21664941]
How do I suppress the inductive kick that’s upsetting the controller?
Add a flyback diode across each relay coil (observing polarity) to block back‑EMF into drivers. For the motor line, use a snubber network or TVS diode rated for the observed spike. Keep high‑current loops short and separated from logic traces. If drivers were stressed before diodes, replace any marginal parts. “Add the diodes, one per relay coil.” [Elektroda, Steve Lawson, post #21664936]
Do I really need flyback diodes on relay coils?
Yes. The relay coil is an inductor. When de‑energized, it generates a high‑voltage transient that can punch into the driver or microcontroller. A reverse‑polarity diode across the coil clamps that spike, protecting hardware and reducing EMI that can flip logic states or corrupt serial data. [Elektroda, Steve Lawson, post #21664936]
What is “inrush current” in this context?
Inrush current is the initial, much higher current a motor draws before it spins up. The stalled rotor looks like a low resistance, so current spikes until back‑EMF builds. That surge can sag supplies, drop out relays, and create mechanical chatter. It’s expected; design for it. [Elektroda, Frank Bushnell, post #21664932]
How should I wire the system to reduce noise and false trips?
Use opto‑isolators on RS232/logic inputs, short and separated traces for relay/motor currents, and solid decoupling on drivers. Keep the logic supply highly stable and filtered. Add mains and DC input filtering to power supplies. Validate cable lengths and shielding to prevent serial data corruption. [Elektroda, Mark Harrington, post #21664943]
Can RS232 or the Bluetooth link be corrupted by the pump starting?
Yes. Inductive spikes and ground bounce can upset the controller, causing missed or retried commands. The board vendor warned that inductive collapse can interfere with logic, and enabling auto‑retry lets the pump start after several attempts. Separate logic power and add suppression to reduce retries. [Elektroda, Steven Furick, post #21664938]
How can I systematically diagnose this dropout?
Try this quick 3‑step:
  1. Scope the relay coil and motor supply during start to spot sag and spikes.
  2. Power the control board from a regulated, separate 12 V supply and retest.
  3. Enable command retries to correlate starts with noise events, then add suppression. These steps reveal whether noise or voltage sag dominates. [Elektroda, Steven Furick, post #21664938]
Is my 5 A relay big enough for a 2.1 A pump?
Maybe not. Contact and coil ratings don’t account for start surges and arcing. The pump runs at 2.1 A, but its start current and inductive kick can exceed a 5 A relay’s comfort zone, causing chatter or early wear. Upsize the relay and add suppression to stabilize switching. [Elektroda, Steven Furick, post #21664931]
Why did a 2 Ω series resistor or parallel capacitors only help sometimes?
Series resistance reduces surge but also slows spin‑up, which can prolong high current. Parallel capacitors can source brief current yet also inject ringing if placed poorly. Without proper snubbers and coil diodes, EMI still reaches logic, so intermittent dropouts persist. Optimize placement and add flyback diodes. [Elektroda, Steven Furick, post #21664931]
Could an overload or safety cutout be tripping at start?
Yes. If an over‑current cutout is set near the motor’s start surge level, it will trip intermittently during startup. Slightly raising the threshold solves erratic cutouts. Always observe battery voltage during start to verify overall supply integrity while adjusting. [Elektroda, Frank Bushnell, post #21664939]
What is an opto‑isolator and why use it here?
An opto‑isolator passes signals using light across an internal gap, isolating grounds. In motor environments it shields microcontrollers and serial ports from spikes and ground shifts. Place optos on RS232 receiver inputs to harden the command path against EMI‑induced glitches. [Elektroda, Mark Harrington, post #21664943]
My battery reads 13 V open‑circuit. Why does the relay still drop out?
Open‑circuit voltage doesn’t reveal internal resistance. Under surge load, a high‑resistance battery sags, starving the relay coil or logic. “It’s more about internal resistance in the battery than Ampere‑Hour capacity.” Test under load, not just at rest. [Elektroda, Steve Lawson, post #21664937]
Could RS232 voltage levels be part of the problem?
Possibly. True RS232 uses ±3 to ±15 V signaling. Marginal levels or missing level shifting can reduce noise margins, especially during EMI events. Verify proper translation between the PC/BT module and the microcontroller, and ensure clean, consistent levels at the receiver. [Elektroda, Steve Lawson, post #21664936]
