Agilent U1253B Multimeter Shows Floating Voltage Readings With Open Probes—Is This Normal?
1014 20
Why does a digital multimeter show unstable fractional-volt readings when the probes are not touching anything on the DC voltage range?
Yes, that is usually normal: with the probes open, the input is floating and the leads can pick up stray EMF/RF/static like antennas, so the meter may show a few millivolts or unstable fractions of a volt [#21666296][#21666297][#21666298] Shorting the probes together should bring the DC reading to near 0, and on AC it is common to still see a small residual reading such as a few mV [#21666307][#21666312] If the meter also shows unusual readings with the probes shorted, try moving it away from nearby RF sources such as a wireless modem or computer and see whether the reading changes [#21666308][#21666310]
  • #1 21666295
    Joseph Sam
  • #2 21666296
    Steve Spence
  • #3 21666297
    Steve Lawson
  • Open probes pick up ambient electromagnetic noise
    #4 21666298
    Frank Bushnell
  • #5 21666299
    Joseph Sam
  • Stray EMI causes floating meter readings
    #6 21666300
    Chuck Sydlo
  • #8 21666302
    Joseph Sam
  • #9 21666303
    Joseph Sam
  • #10 21666304
    Steve Lawson
  • Floating leads can pick up RF or static voltage
    #11 21666305
    Rodney Green
  • #12 21666306
    Rodney Green
  • #13 21666307
    Joseph Sam
  • #14 21666308
    Steve Lawson
  • #15 21666309
    Joseph Sam
  • #16 21666310
    Chuck Sydlo
  • Open probes acting as antenna cause stray readings
    #17 21666311
    Steve Lawson
  • #18 21666312
    Steve Lawson
  • #19 21666313
    Joseph Sam
  • Floating-point explanation for U1253B OLED readings
    #20 21666314
    Mark Harrington
  • #21 21666315
    Mark Harrington
The Agilent U1253B digital multimeter exhibits floating voltage readings of small fractions of volts when its probes are open and not connected to any circuit. This behavior is normal due to the high input impedance and floating input of the meter, which causes the probes to act as antennas picking up ambient electromagnetic interference (EMI) such as 50/60 Hz mains hum, radio frequency (RF) signals, and other electromagnetic radiation present in the environment. These stray voltages result in unstable, low-level AC or DC voltage readings that fluctuate. Shorting the probes together typically stabilizes the reading near zero volts by equalizing the potential and canceling out the interference. The effect is more pronounced on low AC voltage ranges and can also be influenced by nearby sources like wireless modems, computers, transformers, or other EMF emitters. Some users note that even on DC voltage settings, the readings can be unstable but should settle when probes are shorted. The meter’s sensitivity to microvolt levels and the high internal impedance contribute to this phenomenon. Twisting the leads together or moving them closer can reduce the interference. The presence of small current readings on the milliamp scale with open or shorted probes may be due to standing waves or RF pickup on the leads. The issue is generally not a defect but inherent to sensitive digital multimeters with floating inputs. Some users express dissatisfaction with the meter’s documentation and support quality. Additional technical references discuss floating point representation in digital voltmeters and the challenges of shielding and EMI rejection in handheld meters.
TL;DR: Yes—open DMM leads “float,” so you may see noise, often around 10–20 mV, and even up to 1–2 V on cheap meters. “All of my meters indicate voltage on the AC range.” [Elektroda, Steve Lawson, post #21666312]
Why it matters: Knowing this prevents you from misdiagnosing a good meter as faulty and shows how to reduce false readings.
Quick-Facts
Is it normal for a DMM to show voltage with open probes on DC or AC?
Yes. With open probes the input floats and the leads pick up ambient fields, so the reading drifts. This behavior is expected on sensitive digital multimeters. Shorting the probes should bring the reading near zero if the meter is healthy. [Elektroda, Steve Spence, post #21666296]
Why do readings jump more on the AC range?
On AC, the meter is designed to detect alternating signals. Your leads behave like antennas and pick up mains hum and RF. Shorting the probes forces both inputs to the same potential, collapsing the pickup and stabilizing the reading. [Elektroda, Frank Bushnell, post #21666298]
What quick test confirms my meter isn’t faulty?
Short the probes together. A good meter will settle at or near 0 on DC, and to a very small value on AC. If it does not, suspect a setup or hardware issue. “Try shorting the probes together.” [Elektroda, Steve Lawson, post #21666297]
What numbers should I expect with shorted leads on AC?
Quality meters often show about 10–20 mV with shorted leads, while cheaper units can indicate 1–2 V. Both go to zero with ideal shielding, but small residuals are common in normal environments. [Elektroda, Steve Lawson, post #21666312]
My Agilent U1253B shows ±mV to ±0.1 V open-circuit. Is that within reason?
Yes. Users have observed ±mV up to ±0.1 V when the probes float. The value depends on ambient interference and lead geometry. Shorting typically stabilizes near zero, which indicates normal operation. [Elektroda, Joseph Sam, post #21666307]
How do I reduce the wandering reading without special gear?
Use this 3-step fix: 1. Short the probes tip-to-tip. 2. Keep the leads parallel and twist them loosely. 3. Separate the setup from EM sources like transformers. These steps cut loop area and RF pickup. [Elektroda, Steve Lawson, post #21666311]
Can Wi‑Fi routers or PCs in the room cause false readings?
Yes. A nearby wireless modem or computer can couple RF into the leads. Powering them down often reduces or eliminates the apparent voltage. This is a quick diagnostic to try first. [Elektroda, Chuck Sydlo, post #21666310]
Why does the meter show a few millivolts even when probes are shorted on AC?
Small residuals occur from internal noise and residual coupling. Readings like 6–7 mV AC with shorted leads have been observed and are not unusual in typical rooms. [Elektroda, Joseph Sam, post #21666307]
My DC mA range shows ~0.1 mA with open leads. Is that a defect?
Not necessarily. RF can induce currents in the lead loop, especially with quarter‑wave effects. Twist the leads, keep them close, and test again; remove the leads to compare. Persistent DC mA offset may indicate shielding issues. [Elektroda, Steve Lawson, post #21666311]
When should I suspect a real meter fault?
If shorted DC voltage does not settle near 0, or AC readings remain high after twisting and isolating from EM sources, investigate further. That behavior suggests a setup error or a defective meter. [Elektroda, Steve Lawson, post #21666297]
What does “floating input” actually mean on a DMM?
It means the meter’s high-impedance input is not referenced to a defined potential. With open probes, tiny fields move the input, so readings drift until you reference it by shorting or connecting. [Elektroda, Steve Spence, post #21666296]
Could input impedance design affect these symptoms on the U1253B?
Yes. Discussions note input-impedance behavior can influence apparent readings. Reviewing known notes and tests on this model helps separate normal floating behavior from design-specific quirks. [Elektroda, Mark Harrington, post #21666301]
Do analog (moving‑coil) meters behave differently from digital meters here?
Analog meters can rectify RF through protection diodes and show deflection due to nearby RF sources. Digital meters manifest drifting digits instead. Both are reacting to energy picked up by the leads. [Elektroda, Rodney Green, post #21666305]
Can a nearby magnet make the reading jump?
Yes. A strong magnet moved near the leads can induce signals and make readings jump, especially on sensitive ranges. This demonstrates how easily fields couple into open or looped leads. [Elektroda, Chuck Sydlo, post #21666300]
What is a DVM/DMM, and what’s special about the U1253B display?
DVM stands for Digital Volt Meter; DMM measures several quantities. The Agilent U1253B features an OLED display, which is bright and high-contrast compared with LCDs. [Elektroda, Mark Harrington, post #21666314]
