LDO Regulator Overheating Without Load—Is It Safe to Leave Batteries Connected?
399 25
Why does my LDO regulator overheat when the output is unloaded, and is it safe to leave the batteries connected all the time?
The most likely cause is instability/oscillation when the regulator has no proper load and the required capacitors are missing, not the battery being left connected. Add the manufacturer-specified 2.2 µF output capacitor as close as possible to the regulator output pin, and also use the recommended input capacitor for stability [#21666591][#21666588] A simple minimum load of about 10 kΩ from the regulator output to ground can stop the no-load oscillation; the voltmeter can temporarily mask the problem because its input impedance adds a small load [#21666586][#21666593] Also verify the regulator and battery polarity are wired correctly, since several replies noted the schematic appeared reversed at first glance [#21666581][#21666584] With the caps and a small minimum load in place, the LDO should not overheat at the stated currents [#21666586][#21666591]
  • LDO overheats with no load path
    #1 21666569
    Simon Mak
  • #2 21666570
    Steve Lawson
  • #3 21666571
    Peter Evenhuis
  • #4 21666572
    Simon Mak
  • #5 21666573
    Peter Evenhuis
  • Wrong orientation and near-peak LED load cause overheating
    #6 21666574
    Mark Harrington
  • #7 21666575
    Mark Harrington
  • Missing capacitors may be causing LDO heating
    #8 21666576
    Simon Mak
  • Output current limit and missing capacitors may cause shutdown
    #9 21666577
    Mark Harrington
  • #10 21666578
    Simon Mak
  • #11 21666579
    Mark Harrington
  • Warning about unsafe host-family adverts
    #12 21666580
    Mark Harrington
  • #13 21666581
    Earl Albin
  • #14 21666582
    Mark Harrington
  • #15 21666583
    Mark Harrington
  • #16 21666584
    Mark Harrington
  • #17 21666585
    Simon Mak
  • Minimal load resistor may stop LDO oscillation
    #18 21666586
    Earl Albin
  • #19 21666587
    Simon Mak
  • 10 kΩ output resistor to ensure stability
    #20 21666588
    Earl Albin
  • #21 21666589
    Simon Mak
  • #22 21666590
    Mark Harrington
  • Output capacitor placement and inhibit pin grounding
    #23 21666591
    Steve Lawson
  • #24 21666592
    Simon Mak
  • #25 21666593
    Steve Lawson
  • #26 21666594
    Simon Mak
A user testing an LDO regulator circuit with a 3.6V battery supply (3x1.2V cells) observed the LDO overheating when no load was connected, raising concerns about safety with batteries always connected. The discussion identified several key points: the importance of correct polarity and wiring, the necessity of input and output capacitors for stability, and the risk of oscillation in unloaded conditions. The LE33CZ LDO regulator was used, with a maximum output current of 100mA (not 150mA as sometimes misread), and the user’s load of approximately 43mA is within safe limits. Oscillation can cause overheating, which can be mitigated by adding a minimum load resistor (e.g., 10kΩ from output to ground) and proper capacitor placement (2.2µF ceramic capacitor close to output and ground pins). The absence of capacitors in the test setup likely caused instability and heating. Suggestions included verifying correct wiring, adding recommended capacitors, and considering alternative regulators like the ZSAT500C for better thermal performance. Proper layout and adherence to datasheet recommendations are critical to prevent overheating and ensure stable operation.
TL;DR: If your LDO runs hot with no load, add a 10 kΩ minimum load; “put a 10K Ohm resistor on the output.” That adds ~0.33 mA at 3.3 V and tames oscillation. [Elektroda, Earl Albin, post #21666588]
Why it matters: It prevents silent instability that can overheat the regulator and drain batteries.
Who this is for: Makers troubleshooting LE33C/LE33CZ or similar LDOs in battery LED projects, wondering about heat, caps, and safe always-connected batteries.
Why does my LDO overheat when the load is disconnected?
Unloaded LDOs can oscillate. That self‑heating looks like a short, but it’s instability. A handheld DVM can temporarily load and calm it, hiding the issue. Add a permanent minimum load to keep the regulator in a stable region when your switch removes the LEDs. [Elektroda, Earl Albin, post #21666586]
Is it safe to leave the batteries connected when the switch removes all loads?
Yes, if the regulator is stable at no‑load. Add a 10 kΩ from OUT to GND and include the proper input/output capacitors. This prevents oscillation and heat while the LEDs are off. “Resolving an oscillation is the easy part.” [Elektroda, Earl Albin, post #21666586]
How do I wire the minimum load—before or after the output capacitor?
Tie the resistor directly from the regulator’s OUT pin to ground at the output node. That way it always loads the regulator, regardless of the LED switch state. This is the intended minimum‑load connection. [Elektroda, Steve Lawson, post #21666593]
What value should the minimum load be, and what current does it draw?
Use 10 kΩ from OUT to GND. At 3.3 V, that draws about 0.33 mA (3.3 V ÷ 10 kΩ). The current is tiny yet enough to stop no‑load oscillation in many builds. “Put the 10K Ohm resistor on the output.” [Elektroda, Earl Albin, post #21666588]
Do I really need the capacitors, and where should they go?
Yes. Add the specified 2.2 µF on OUT for stability. Place it as close as possible to the OUT and GND pins. Keep input and output routing separated, and avoid running ground return currents through the cap’s ground lead. Follow the datasheet layout guidance. [Elektroda, Steve Lawson, post #21666591]
Can missing capacitors alone make an LDO run hot or misbehave?
Yes. The manufacturer calls the 2.2 µF output capacitor a stability requirement. Skipping it can cause oscillation, voltage droop, and heat. Good placement and grounding further improve stability and noise. [Elektroda, Steve Lawson, post #21666591]
My output sags when I connect a load—what should I check first?
Confirm you’re not hitting the regulator’s current limit and that thermal protection isn’t engaging. Design well below the rated 100 mA; avoid peak‑limit operation. Poor layout or missing caps also cause droop. Add the minimum load only for stability, not to increase capacity. [Elektroda, Mark Harrington, post #21666577]
What’s the simplest 3‑step fix to stabilize this LDO test setup?
  1. Add a suitable input capacitor close to the IN/GND pins.
  2. Add a 10 kΩ resistor from OUT to GND as a minimum load.
  3. Verify the regulator now stays cool and the output is steady. [Elektroda, Earl Albin, post #21666588]
Could reversed wiring or a schematic typo cause the heat problem?
Yes. Reversing input/output or battery polarity can create catastrophic stress and heat. Double‑check symbol orientation and pin mapping before powering. A mistaken connection can turn a demo into a “marshmallow roaster.” [Elektroda, Earl Albin, post #21666581]
Does a DVM on the output really change behavior?
Yes. The meter’s input impedance adds a small load that can stop oscillation temporarily, making the LDO appear cooler or more stable during measurement. Don’t rely on this; add a fixed resistor. [Elektroda, Earl Albin, post #21666586]
Do I need to ground the INHIBIT/ENABLE pin?
If you use a version with an inhibit pin, don’t leave it floating. Tie it to ground to disable, or drive it firmly. Floating control pins introduce unpredictable behavior and instability. [Elektroda, Steve Lawson, post #21666591]
What output current should I design for with LE33C/LE33CZ?
Target well below the “up to 100 mA” rating to keep temperature and dropout in check. The 150 mA figure refers to protection limiting, not a usable continuous spec. Leave margin for ambient heat and LED surges. [Elektroda, Mark Harrington, post #21666577]
Will three 1.2 V cells (≈3.6 V) work with a 3.3 V LDO for LEDs?
Yes, as shown by the OP’s test supply. Ensure dropout plus wiring losses still leave at least 3.3 V at the load. Stability components and a small minimum load are still required. [Elektroda, Simon Mak, post #21666572]
Can an LDO oscillate without an output capacitor fitted?
Some won’t in a given layout, but don’t count on it. Use an input cap and add a 10 kΩ minimum load; these two steps often fix the issue quickly during bring‑up. [Elektroda, Earl Albin, post #21666588]
