How to Build a High-Frequency Electronic Lighter for Biogas Ignition
327 7
  • #1 21667077
    Vikas Patel
  • #2 21667078
    Rodney Green
  • #3 21667079
    Sarah Harris
  • #4 21667080
    Steve Spence
  • Clarifying power, range, and spark requirements
    #5 21667081
    Steve Lawson
  • #6 21667082
    Richard Comerford
  • #7 21667083
    Rodney Green
  • #8 21667084
    Mark Harrington
The discussion focuses on designing a high-frequency electronic lighter capable of igniting biogas, which requires a strong and frequent spark due to its density. A practical approach involves using an automobile ignition coil driven by a MOSFET transistor to generate powerful sparks. The ignition coil can be controlled via a 555 timer IC for simple electronic ignition or an Arduino microcontroller for more advanced control. It is emphasized that spark size alone is insufficient; the correct oxygen-to-gas mixture is critical for successful combustion. Alternative ignition methods such as piezoelectric drives are suggested if power availability is limited. Reusing ignition circuits from gas stoves or boilers is also proposed as an easy solution. Additional considerations include the operating environment, power source, remote control distance, spark gap exposure to flame, and the desired spark frequency or duration.
