SW584 External Battery Not Charging iPhone 4S—Possible Compatibility or Cable Issue?
321 6
  • Charge the power bank before charging the phone
    #2 21667318
    Frank Bushnell
  • #3 21667319
    Huanqiu
  • #4 21667320
    Mark Harrington
  • #5 21667321
    Mark Harrington
  • #6 21667322
    Mark Harrington
  • Using a 150 W inverter to charge in car
    #7 21667323
    Aloce Jorsen
The SW584 external battery is a 9000 mAh portable power bank designed to recharge devices like the iPhone 4S. It must be fully charged via a USB port (typically 0.5A output) before it can charge a phone. Charging the battery unit from empty can take approximately 18 hours. Once charged, it can recharge an iPhone 4S battery (around 1000 mAh) multiple times, accounting for system efficiency losses. Users should ensure the external battery is charged first and then connect it to the phone. Additional advice includes using proper casing and heat dissipation for the battery unit. Alternative charging methods such as using a 150W power inverter connected to a car cigarette lighter outlet were also mentioned for charging iPhones on the go. The discussion highlights compatibility considerations and the importance of verifying the external battery's charge state before use.
