How Can I Make 12V LED Strips Pulse to Bass in My Car Using a Safe Circuit Design?
318 9
How can I make 12V LED strips pulse to the bass output in my car without wiring them directly to the subwoofer?
Use a bass-extractor/low-pass RC filter feeding a transistor driver for the LED strips instead of connecting the strips directly to the subwoofer. If the signal is already a subwoofer output, the high frequencies are likely already removed, so a separate low-pass filter may not be necessary; if it is full-range, a simple RC filter should work [#21668404][#21668407] For the rectifier diode, use a 1N4004 rather than a 1N4148 because the speaker peak voltage can reach about 90–110 V and the 1N4004’s 400 V PIV gives more margin [#21668407] If the LEDs do not light when expected, reduce C1 to raise the RC cutoff frequency, and a sensitivity control is a good addition [#21668407] The 100 Ω series resistors are not needed for 12 V LED strips if they are being powered directly from 12 V, and the suggested resistor wattages are low: about 20 mW for the 50 kΩ pot at 500 W average power, so 1/8 W or higher is fine for the 47 kΩ and 220 kΩ parts [#21668407][#21668411]
  • Need for transistor switch and fade capacitor
    #1 21668402
    Sean Pittman
  • Use a low-pass filter and drive transistor
    #2 21668403
    Mark Harrington
  • #3 21668404
    Steve Lawson
  • #4 21668405
    Sean Pittman
  • #5 21668406
    Steve Lawson
  • Use 1N4004 and remove series LED resistors
    #6 21668407
    Steve Lawson
  • #7 21668408
    Steve Lawson
  • #8 21668409
    Sean Pittman
  • #9 21668410
    Sean Pittman
  • Power dissipation calculations for 50 kΩ pot and resistors
    #10 21668411
    Steve Lawson
A first-year electrical engineering student seeks advice on designing a safe circuit to make four 12V LED strips pulse in sync with bass from a 3000W peak power car amplifier. The student notes that directly wiring LEDs in parallel with subwoofers is ineffective and damaging. Responses recommend using a beat extractor circuit with a low-pass or simple RC filter to isolate bass frequencies, driving the LEDs via a transistor switch. It is advised to replace 1N4148 diodes with more robust 1N4004 diodes due to higher peak inverse voltage tolerance suitable for speaker output voltages. The use of series resistors with 12V LED strips is questioned, as LED strips typically require direct 12V supply without current-limiting resistors. Adjusting the capacitor value in the RC filter can tune the cutoff frequency for better LED response. Power dissipation calculations for resistors and potentiometers are provided, suggesting 1/8W or 1/4W ratings depending on voltage and resistance values. The discussion emphasizes proper filtering, transistor switching, and component selection to achieve safe and effective bass-synced LED pulsing in automotive audio applications.
