Choosing Electric Motor and Battery Setup for 400kg Personal Submarine Build
336 6
  • Sizing motor and battery for a 400 kg submarine
    #1 21668813
    Jonathan Pepper
  • Recommend isolating motor and pump power supplies
    #2 21668814
    Alexander Lee
  • Separate control electronics from motor power supply
    #3 21668815
    Jonathan Pepper
  • Recommend marine motor, gel batteries, and ballast systems
    #4 21668816
    Peter Evenhuis
  • #5 21668817
    Mark Harrington
  • #6 21668818
    Ruben Proost
  • #7 21668819
    Frank Bushnell
A mechanical engineer plans to build a one-person, 400 kg personal submarine powered entirely by an electric motor and rechargeable batteries, aiming for about one hour of operation with rear-mounted propulsion and energy storage. Key considerations include electrical isolation between high-current motor/pump circuits and sensitive control electronics to prevent voltage spikes caused by motor inductance and switching. Using separate power sources or isolated circuits for propulsion and control systems is recommended. Gel batteries, commonly used in solar applications, are suggested for energy storage due to their availability and suitability. For propulsion, selecting a ready-made marine motor with integrated propeller is advised to minimize water leakage risks. Motor speed control can be achieved via DC/DC or DC/AC converters depending on motor type. Additional systems such as ballast pumps, tanks, level and valve position indicators, compressed air tanks, and possibly an air compressor are necessary for submarine operation. Determining motor and battery sizing requires prior knowledge of desired speed and water displacement. Researching electric car charging systems and DIY submarine projects is encouraged to leverage existing knowledge on plug-in rechargeable power systems and submarine electronics.
