Best Alternator to Power 200W 24V/36V DC Motor With 30cm 15kg Flywheel Setup
303 15
What type of alternator or generator should I use to power a 200 W 24 V/36 V DC motor from a flywheel-driven setup, and how much resistance or load will it add?
A car alternator is not the right choice here; a permanent-magnet DC generator/motor is better, and 30–90 VDC motors from treadmills or electric lawnmowers were suggested as suitable alternatives [#21669282] A flywheel is only an energy storage device, not a power source, so the real issue is what is providing the torque to spin it [#21669273][#21669278] For a human-sized drive source, expect about 100 W sustained output and only about 10 A at 12 V; 60 A at 12 V is not realistic, and a car alternator typically needs a few thousand rpm while its field coils consume most of the available power [#21669282] If you convert torque to electricity and then back to torque with another alternator/motor stage, each conversion loses roughly 40% to heat and friction, making the chain very inefficient [#21669277][#21669275] So there is no useful “cog setting” that will magically give 200 W out of the alternator; you need a proper prime mover and a generator matched to the speed and voltage you actually need [#21669278][#21669282]
  • Alternator output limited by shaft power and inefficiency
    #1 21669269
    Steve Spence
  • Alternator voltage depends on spin rate
    #2 21669270
    Private
  • DC-DC converter needed for voltage changes
    #3 21669271
    Steve Spence
  • Flywheel inertia can drive an alternator directly
    #4 21669272
    Private
  • #5 21669273
    Steve Spence
  • #6 21669274
    Private
  • #7 21669275
    Steve Spence
  • #8 21669276
    Private
  • #9 21669277
    Chuck Sydlo
  • Alternator shaft resistance under 200 W load
    #10 21669268
    Private
  • #11 21669278
    Steve Spence
  • Questioning AC generation and direct AC motor drive
    #12 21669279
    Private
  • Magnets are not a power source
    #13 21669280
    Steve Spence
  • Asking about coil wire thickness for ferrofluid core test
    #14 21669281
    Private
  • Permanent magnet generator better than car alternator
    #15 21669282
    Steve Spence
  • Questioning ferrofluid and iron filings in a coil
    #16 21669283
    Private
The discussion centers on selecting an appropriate alternator to power a 200W DC motor operating at 24V or 36V, integrated with a 30cm diameter, 15kg flywheel. Key points clarify that an alternator's output current is limited by its rated capacity and that mechanical input torque must exceed electrical output by approximately 140% due to inefficiencies. Flywheels serve as kinetic energy storage, not energy sources, requiring an external power input to maintain rotation. Alternators produce AC voltage proportional to rotational speed, which can be rectified to DC; transformers cannot convert DC voltage, so DC-DC converters are necessary for voltage adjustment with associated losses (~10%). Energy conversion losses in alternators and motors are significant, roughly 40% per stage, compounding when using multiple alternators in series. The human body can sustain about 100W mechanical power, making it a limited power source for such setups. Permanent magnet generators are preferable over standard car alternators for low-speed, human-powered applications due to lower field coil power consumption. The use of ferrofluid and iron fillings inside coils was queried for potential electromagnetic effects, but no definitive conclusions were provided. Overall, the project requires careful consideration of mechanical input power, alternator efficiency, and realistic expectations of energy conversion losses.
TL;DR: For a 200 W, 24–36 V target, plan ~140% shaft power and prefer a 30–90 V permanent‑magnet DC motor as generator; “The magnets contain no potential power.” [Elektroda, Steve Spence, post #21669282]
Why it matters: This FAQ helps DIYers pick realistic parts and wiring to power a 24–36 V, 200 W load without wasting effort.
What’s the best alternator or generator to power a 200 W 24/36 V DC motor?
Use a permanent‑magnet DC motor (30–90 V) as a generator, not a car alternator. It produces voltage at human‑achievable RPM and avoids field‑coil losses. A car alternator wants thousands of RPM and wastes your limited pedal power. [Elektroda, Steve Spence, post #21669282]
How much mechanical power do I need at the shaft to get 200 W electrical?
Budget roughly 1.4× your electrical target. For 200 W out, plan about 280 W into the shaft to cover typical alternator losses and inefficiency. That overhead comes from load‑dependent drag and heat. [Elektroda, Steve Spence, post #21669269]
Do alternators cog, and what resistance will I feel at 200 W load?
Automotive alternators don’t cog like permanent‑magnet machines. Drag rises with current draw and inefficiency, so resistance is light at no‑load and noticeable under 200 W. Expect significant load‑proportional torque. [Elektroda, Steve Spence, post #21669269]
Can a flywheel be my energy source?
No. A flywheel only stores energy; it does not create it. You must supply torque first, then the flywheel smooths power and bridges short bursts. “A flywheel is a energy storage device, like a battery.” [Elektroda, Steve Spence, post #21669273]
Can I drive one alternator with another to boost power?
Avoid alternator‑to‑alternator chains. Each mechanical↔electrical conversion loses about 40%, so two stages compound losses and waste most of the input torque. It’s a classic efficiency trap. [Elektroda, Chuck Sydlo, post #21669277]
Will a car alternator work for human‑powered 24–36 V output?
It’s a poor match. Car alternators need high RPM and their field coil can consume much of a rider’s power. A PMDC motor used as a generator is simpler and more efficient for pedaling. [Elektroda, Steve Spence, post #21669282]
How many amps can a human realistically produce at 12 V?
About 10 A is realistic for short periods; 60 A at 12 V from human pedaling is not. Human sustained output is around 100 W, so current is limited by both voltage and rider stamina. [Elektroda, Steve Spence, post #21669282]
What RPM should I target?
Automotive alternators expect a few thousand RPM to reach rated current, which is hard by pedal. PMDC generators produce voltage roughly proportional to RPM, making them workable at modest speeds. [Elektroda, Steve Spence, post #21669282]
Are magnets themselves a power source?
No. Magnets enable conversion but don’t provide energy. “NO, you cannot produce work with magnets.” You must input mechanical work to get electrical output. [Elektroda, Steve Spence, post #21669280]
Do I need a transformer or DC‑DC converter for 24–36 V systems?
Transformers only work on AC. DC cannot be transformed directly, so use a DC‑DC converter to change DC voltage, accepting about 10% conversion loss in the process. [Elektroda, Steve Spence, post #21669271]
How should I couple a 30 cm, 15 kg flywheel to hit a 200 W draw?
Set gearing so the generator spins in its efficient range while you can sustain cadence. Drag rises with electrical load and inefficiency, so adjust pulley ratio to maintain cadence under about 200 W. [Elektroda, Steve Spence, post #21669269]
Quick How‑To: Build a 24–36 V pedal generator that can deliver ~200 W
  1. Select a 30–90 V PMDC motor as your generator and gear it to comfortable cadence.
  2. Rectify/regulate as needed and feed a 24–36 V battery or motor controller.
  3. Add a flywheel only for smoothing; it won’t increase net energy. [Elektroda, Steve Spence, post #21669282]
Could ferrofluid or iron filings inside a coil boost output?
Focus on proven PMDC‑generator designs instead. The core message: your legs are the energy source; magnets and materials only shape conversion. Prioritize low‑loss generators over exotic coil fillers. [Elektroda, Steve Spence, post #21669282]
Why does resistance feel low when the alternator is unloaded?
With no load, current is minimal, so mechanical drag is small. As electrical draw rises, copper and conversion losses grow, increasing shaft torque demand and the pedaling effort you feel. [Elektroda, Steve Spence, post #21669269]
Can an alternator also act as a motor out of the box?
Automotive alternators are not motors without modification. Treat them as generators only; if you need motor function, use a proper motor or a modified unit. [Elektroda, Steve Spence, post #21669278]
