Dayton 1EJE9 DPDT Time Delay Relay Wiring for 208V 3-Phase Heater Fan/Louver Control
501 8
  • Clarifying 208V three-phase relay control wiring
    #1 21669632
    Chris LeBlanc
  • Request for 1EJE9 datasheet and wiring diagrams
    #2 21669633
    Mark Harrington
  • #3 21669634
    Chris LeBlanc
  • #4 21669635
    Mark Harrington
  • Clarifying trigger source and thermostat wiring
    #5 21669636
    Mark Harrington
  • #6 21669637
    Mark Harrington
  • S trigger voltage needs manufacturer confirmation
    #7 21669638
    Mark Harrington
  • Check S trigger voltage and isolation first
    #8 21669639
    Mark Harrington
  • #9 21669640
    Mark Harrington
The discussion centers on wiring a Dayton 1EJE9 DPDT time delay relay for controlling a 208V 3-phase heater fan and electric louver system using the Off Delay function (function "D"). The user intends for the fan and louvers to activate with the heater and remain on for a set delay after the heater turns off. The relay coil voltage rating is 12-240VAC/DC with a 3VA rating, and the relay contacts are rated for 15A resistive and 7A inductive loads. The main wiring question concerns the correct control power connections: whether to use one line of the constant three-phase supply on terminal A1, ground on A2, and the switched line on terminal S. Testing with 24VDC signals on these terminals showed the relay functioning correctly, but the user seeks confirmation for 208V 3-phase application. Responses emphasize the importance of verifying the trigger voltage and isolation requirements for terminal S, which is not clearly specified in the datasheet. It is recommended to confirm the maximum and minimum trigger voltages for terminal S, whether it is isolated from the coil, and the required trigger current. Suggestions include using an optocoupler or isolation transformer to safely interface the relay coil with the control circuit, especially if the thermostat or trigger source operates at different voltages. The user’s schematic was reviewed and found generally correct, but caution is advised to ensure the trigger input voltage and isolation conform to manufacturer specifications to avoid electrical hazards.
