Wiring a 230V Machine Relay: Where to Connect Power Supply and Motor?
555 24
How do I wire the mains supply and motor to this 230V relay?
Wire the coil control to the A1 and A2 terminals, and use the two switched contact pairs for the mains and the motor. The relay appears to be a DPST device, so the 230V mains feed goes on one side of the contact set and the motor connects to the other side of the same contact set [#21682066] The corrected terminal layout in the thread is: mains live and neutral to the right-hand NO2 contacts, and motor live and neutral to the left-hand NO2 contacts [#21682068][#21682069] Before connecting anything, check the relay with a multimeter: A1/A2 should show coil resistance, NO contacts should be open when de-energized, and the contacts should close when the relay is activated [#21682066] If you do not have a multimeter or are unsure, do not proceed and get qualified help, because 230V can be lethal [#21682066]
  • #1 21682064
    Mark Porteous
  • DPST relay wiring with A1 and A2 coil pins
    #2 21682065
    Rick Curl
  • Relay pinout and contact tests with multimeter
    #3 21682066
    David Ashton
  • Corrected relay contact resistance guidance
    #4 21682067
    David Ashton
  • #5 21682068
    Jack Grubbs
  • #6 21682069
    David Ashton
  • Testing 230V relay coil and NO contacts
    #7 21682070
    Ruby Mullins
  • 230V coil test and contact resistance check
    #8 21682071
    Ruby Mullins
  • #9 21682072
    avril12 cafe
  • #10 21682073
    David Hoppins
  • #11 21682074
    marker hook
  • #12 21682075
    nilee thoumus
  • #13 21682076
    roshi meri
  • #14 21682077
    rush deo
  • #15 21682078
    rush deo
  • #16 21682079
    rush deo
  • #17 21682080
    layla dosh
  • #18 21682081
    jenilia122 cafe
  • #19 21682082
    layla dosh
  • #20 21682083
    kanishk246 markel
  • #21 21682084
    scott99 cafe
  • #22 21682085
    kanishk246 markel
  • #23 21682086
    kanishk246 markel
  • #24 21682087
    Ben Green
  • #25 21682088
    vaish prathyusha
The discussion addresses wiring a relay for a 230V machine, focusing on correct connections for the power supply and motor. The relay is identified as a DPST (double pole single throw) type with coil terminals labeled A1 and A2 on the right side. The 230V mains power should be connected to the two pins on the left, while the motor connects to the remaining two pins. Users are advised to verify coil voltage and resistance between A1 and A2 using a multimeter before wiring. Activation of the relay should produce an audible click and near-zero resistance across normally open (NO) contacts NO1 and NO2. Safety precautions are emphasized due to the high voltage, including using insulated lugs and seeking qualified assistance. The large lug on the right is likely a mounting point and should not be connected electrically. For motors exceeding 1 kW, a contactor rather than a relay is recommended. Additional advice includes verifying motor wiring for dual-voltage compatibility and proper grounding.
TL;DR: For a 230V DPST relay, typical motor limit is 1–2 hp, and “230V can kill you easily!” Wire lives to NO1, neutrals to NO2, coil to A1/A2. Test with a multimeter before energizing. [Elektroda, Anonymous, post #21682066] Why it matters: Wrong connections or testing on live mains can destroy motors—or you.
How do I wire the power supply and motor on a 230V DPST relay?
Use the two NO1 terminals for live conductors and the two NO2 terminals for neutrals. Connect mains live to one NO1, motor live to the other NO1. Connect mains neutral to one NO2, motor neutral to the other NO2. Connect the coil to A1 and A2. Verify with a multimeter before applying power. [Elektroda, Anonymous, post #21682068]
Which pins are the relay coil, and how do I confirm them?
The coil pins are A1 and A2. Measure resistance across A1–A2 with power off. You should read finite resistance, typically a few to a few hundred ohms. Zero ohms indicates a short, and infinite suggests an open coil. Do not energize a suspect coil. [Elektroda, Anonymous, post #21682066]
What does DPST mean on a relay?
DPST means Double Pole, Single Throw. One coil actuates two separate normally open contacts together. This lets you switch both live and neutral with one relay action for better isolation on 230V equipment. [Elektroda, Anonymous, post #21682065]
How do I test the relay safely before wiring it into my machine?
Work de‑energized. 1. Identify A1/A2 and measure coil resistance. 2. Check both NO1 and NO2 pairs are open (infinite resistance). 3. Apply the correct coil voltage with insulated lugs; you should hear a click and see near‑zero ohms across NO1 and across NO2. If not, stop. [Elektroda, Anonymous, post #21682066]
Can this relay start a larger motor, like 3 hp?
No. The guidance indicates about 1–2 hp (~1 kW) is the practical upper bound for this relay. For larger motors, use a proper contactor designed for motor inrush and endurance. “You need a thing called a contactor.” [Elektroda, Anonymous, post #21682066]
Is the large metal lug on the side a connection point?
No. The large lug shown is a mounting point. It must not be wired to any contact. Treat it as mechanical only to avoid shorts or shocks. [Elektroda, Anonymous, post #21682066]
What if I don’t own a multimeter?
Do not proceed. The thread explicitly warns to stop without proper test gear and skills. Hire a qualified electrician. “The money you spend on an electrician is worth it to be sure you will live out your natural life!” [Elektroda, Anonymous, post #21682066]
How do I know the correct coil voltage for A1/A2?
Read the relay’s markings and match your control source. If it is a 230V coil, treat testing as a live‑mains operation and use insulated lugs. Never guess coil voltage, as mispowering can destroy the relay or shock you. [Elektroda, Anonymous, post #21682066]
Should neutral go to NO1 or NO2 on this relay?
Use NO2 for neutral conductors. Place mains neutral on one NO2 terminal and motor neutral on the other NO2 terminal. This corrects an earlier mix‑up noted in the discussion. [Elektroda, Anonymous, post #21682068]
Why switch both live and neutral on 230V gear?
Using both poles of a DPST relay isolates the motor from mains on both conductors when off. That reduces shock risk during service and avoids stray energization paths. It also matches the contact layout described for NO1 and NO2. [Elektroda, Anonymous, post #21682066]
When must I use a contactor instead of a relay?
Use a contactor for motors beyond ~1–2 hp or where frequent starts occur. Contactors handle high inrush and offer better endurance. The thread flags contactors for heavier duty motor control. [Elektroda, Anonymous, post #21682066]
What are signs I wired or tested the relay incorrectly?
Red flags include zero ohms across A1–A2 (shorted coil), continuity across NO contacts when de‑energized, or no click on coil power. Any mismatch from the test steps means stop and recheck. Do not energize the motor until readings match expectations. [Elektroda, Anonymous, post #21682066]
