Wiring 120VAC Outlet Controlled by Digital Thermostat Using 24VAC Relay and Transformer
285 7
  • #1 21675417
    Roy Andrews
  • #2 21675418
    Kevin Angelo Ma
  • #3 21675419
    richard gabric
  • 24 VAC relay and transformer selection confirmed
    #4 21675420
    Roy Andrews
  • 24vac relay and thermostat voltage tolerance question
    #5 21675421
    Roy Andrews
  • Thermostat operating voltage is 20–30 VAC
    #6 21675422
    Roy Andrews
  • Need total load power under 15 A at 120 VAC
    #7 21675423
    richard gabric
  • 15A outlet rating and 14-2 Romex wiring clarified
    #8 21675424
    Roy Andrews
The discussion centers on wiring a 120VAC outlet controlled by a digital thermostat using a 24VAC transformer and a 24VAC-to-120VAC relay. The proposed components include a TE Connectivity 24VAC relay (model 655-K10P-11AT1-24) and a 120VAC-to-24VAC transformer (model 655-4000-01E07K999) sourced from Mouser Electronics. The thermostat operates at 24VAC on the R terminal, compatible with both analog and digital types, including the Honeywell TH3110D1008 and Nest Learning Thermostat, which accept 20-30VAC input. The outlet and relay must support a load of up to 15A at 120VAC, suitable for a 1500W heater drawing approximately 12.5A. Wiring uses standard 14-2 Romex cable with hot, neutral, and ground conductors. Safety considerations include compliance with fixed wiring regulations and ensuring all components meet current and voltage ratings for the intended load. The relay's operate voltage is 20.4VAC with a release voltage of 2.4VAC, rated at 24VAC, ensuring proper switching with the thermostat output.
