Burnt electrical “item” in power board – need help knowing what is it called
270 7
  • Likely failed surge suppressor or capacitor from overvoltage
    #1 21669821
    Ahmed Ramahi
  • Voltage converter likely damaged the MOV surge suppressor
    #2 21669822
    DAVID CUTHBERT
  • MOVs vary by voltage, size, and energy rating
    #3 21669823
    Ahmed Ramahi
  • #4 21669824
    DAVID CUTHBERT
  • Travel converter output still has 240 V peak
    #5 21669825
    DAVID CUTHBERT
  • Replacing MOVs and reverting to transformer supply
    #6 21669826
    Ahmed Ramahi
  • #7 21669827
    Ahmed Ramahi
  • #8 21669828
    DAVID CUTHBERT
A 120V coffee maker rated at 900W was used with a 1600W step-down voltage converter from Radio Shack in a 220V region, resulting in a burnt blue rounded component inside the converter. The damaged component was identified as an MOV (Metal Oxide Varistor), which protects against voltage spikes but failed due to the converter's waveform characteristics. The voltage converter is suitable only for resistive heating elements and not for electronic devices like the coffee maker, which requires a true transformer providing a stable 120VAC supply. The MOV can be replaced with one rated for approximately 130VAC and similar physical size to restore transient voltage protection. Testing and operation require a proper 120VAC source. A recommended replacement MOV model is the MOV-10D201KTR, available from Digikey, with datasheet specifications provided by Bourns. The original voltage converter likely produced a chopped waveform with a peak voltage of 340V, unsuitable for the coffee maker's electronic control board. The user successfully replaced the MOV and reverted to a large transformer from ACE Hardware, restoring the coffee maker's functionality.
