PIC16F785 Microcontroller Solar Battery Charge Controller Circuit Design Guide
459 7
  • #1 21669999
    Xombi Nash
  • 555 timer solar charger with adjustable thresholds
    #2 21670000
    Syed Shadab
  • #3 21670001
    Suchithra ravikumar
  • #4 21670002
    Xombi Nash
  • #5 21670003
    Xombi Nash
  • #6 21670004
    DAVID CUTHBERT
  • #7 21670005
    Suchithra ravikumar
  • #8 21670006
    Otto Sponring
The discussion focuses on designing a solar battery charge controller using the PIC16F785 microcontroller. While a simple 555 timer-based charger circuit with adjustable voltage thresholds is suggested for basic applications, it is noted that such designs have efficiency limitations. The PIC16F785 MCU enables implementation of advanced features like Maximum Power Point Tracking (MPPT) using buck-boost converter techniques to optimize solar panel output and battery charging efficiency. The choice of battery chemistry, such as LiFePO4 for longer life, and the number of cells (2 or 4) influences the charger design. Indicators for battery charging and discharging status can be implemented using LEDs interfaced with the microcontroller. Autonomous charging circuits without microcontrollers are possible but lack the flexibility and optimization provided by MCU-based designs.
