How to Test and Replace Diodes in HP 19V 4.74A 90W Laptop Charger with 0V Output
357 11
How can I test the diodes in an HP 19 V 4.74 A laptop charger that has 0 V output?
Test the diodes with the charger unplugged using your multimeter’s diode-test range; a good diode should read about 0.6–0.7 V in the forward direction and OL/open in reverse, while near-0 Ω both ways indicates a short and OL both ways indicates an open diode [#21670810][#21670812] If the charger is rectifying AC, an oscilloscope across the rectifier can confirm operation, and you can also trace the circuit backward from the output toward ground until the voltage disappears to localize the fault [#21670808][#21670812] If your meter has no diode mode, resistance checks can still help, but interpret them as open/short rather than as a full diode test [#21670810] Also check common non-diode faults such as loose plugs, broken wires, dry joints, dirty contacts, the fuse, and input/output wiring before replacing parts [#21670808][#21670816][#21670817]
  • Output shorted to ground caused 0V charger output
    #1 21670807
    Luis Cruz
  • Diode test methods and bad connection faults
    #2 21670808
    Frank Bushnell
  • #3 21670809
    Luis Cruz
  • #4 21670810
    Steve Lawson
  • #5 21670811
    Luis Cruz
  • Backtrack from output to locate fault area
    #6 21670812
    David Figueroa
  • Universal charger fails to supply 90W under load
    #7 21670813
    Luis Cruz
  • Battery may be masking an underpowered charger
    #8 21670814
    Frank Bushnell
  • #9 21670815
    Luis Cruz
  • Loose charger plug wires can cause intermittent output
    #10 21670816
    Frank Bushnell
  • #11 21670817
    Waseem Bari
  • #12 21670818
    Luis Cruz
An HP laptop charger rated at 19V, 4.74A (~90W) exhibited a 0V output and error beeping. The issue was initially suspected to be faulty diodes on the PCB near the transformer. Testing methods for diodes were discussed, including using a multimeter in diode test mode to check forward voltage (~0.6-0.7V), measuring resistance in both directions to identify shorts or opens, and using an oscilloscope for AC rectifying diodes. It was advised to test diodes out of circuit for accurate readings. Common faults such as dry joints, corroded contacts, blown fuses, and loose wiring inside the charger or laptop input socket were also highlighted. The original problem was resolved by identifying a short circuit between ground and output. A secondary issue with a universal 12-20V 3-4.74A charger (Trust brand) not charging the laptop properly was discussed, likely due to underpowered supply or poor quality components. Testing for voltage stability and cable integrity was recommended.
TL;DR: For HP 19V×4.74A (≈90W) chargers showing 0V, first check for GND–Vout shorts and connector faults; “A large proportion of faults are due to a simple bad connection.” [Elektroda, Frank Bushnell, post #21670808]
Why it matters: This FAQ helps DIYers quickly diagnose no‑output and diode faults in 90W HP-style laptop PSUs using only a meter.
How do I test a charger diode with only a multimeter?
Power off and discharge capacitors. Use the meter’s diode mode. Forward bias should read ~0.6–0.7 V. Reverse bias should read OL. If your meter lacks diode mode, use resistance: one direction low, the other very high. “Infinite both ways means open.” [Elektroda, Steve Lawson, post #21670810]
Do I need to desolder diodes to test them accurately?
Often yes, because parallel paths can skew readings in‑circuit. Lift one lead to isolate the junction if results look ambiguous. Then repeat the forward/reverse test to confirm ~0.6–0.7 V forward drop and OL reverse. [Elektroda, Steve Lawson, post #21670810]
My HP 90W charger shows 0 V at the output—what’s the first check?
Check for a short between GND and Vout at the DC connector. A hard short will pull the output to 0 V and can trigger protection. Clearing the short restores normal voltage. [Elektroda, Luis Cruz, post #21670807]
What does 0 Ω both ways vs. infinite both ways mean on a diode?
0 Ω measured both directions indicates a shorted diode. Infinite resistance both directions means an open diode. Only one conducting direction is acceptable for a good junction. [Elektroda, Steve Lawson, post #21670810]
How can I trace the fault when the adapter reads 0 V?
Start at the output and move backward toward the transformer. Keep your black lead at ground and probe stages until voltage reappears. The failure lies near the transition point. [Elektroda, David Figueroa, post #21670812]
What does “rectifying AC” mean for the charger’s diodes?
Those diodes convert transformer AC into DC. In operation you can scope across them; powered off, use the meter’s diode mode. Expect about 0.6 V across a conducting silicon diode. [Elektroda, Frank Bushnell, post #21670808]
Universal 12–20 V adapter says connected but not charging—why?
It may be under‑rated or sags under load. Without the battery buffering, voltage droop can halt charging and cause shutdowns. Set the correct voltage and ensure current capacity matches 90 W. [Elektroda, Frank Bushnell, post #21670814]
Laptop powers off ~2 seconds after removing the battery on adapter power—root cause?
Your adapter cannot sustain load transients. The voltage dips and the laptop’s protection shuts it down about 2 seconds later. Use a 19 V, 4.74 A capable supply in good condition. [Elektroda, Luis Cruz, post #21670813]
How do I check for intermittent plug or cable faults?
Perform a wiggle test. Power the supply, connect a load or LED+resistor, and gently flex the DC plug and strain relief. Flicker or drops confirm a cable or connector failure. [Elektroda, Frank Bushnell, post #21670816]
Should I check the input fuse, and where?
Yes. The fuse sits on the AC input side of the PCB. Verify continuity. Replace if open, as supply fluctuations often blow it. If it’s good, continue downstream checks. [Elektroda, Waseem Bari, post #21670817]
What forward voltage should I see across a good diode in-circuit?
Expect around 0.6–0.7 V across a forward‑biased silicon diode. Read it with diode mode. Reverse‑biased should read OL or very high impedance. [Elektroda, Steve Lawson, post #21670810]
3‑step how‑to: Test a suspect diode quickly
  1. Power off and discharge. Lift one diode lead if possible.
  2. Meter in diode mode: forward ≈0.6–0.7 V; reverse OL.
  3. If 0 V both ways, it’s shorted; OL both ways, it’s open. [Elektroda, Steve Lawson, post #21670810]
Can output shorts alone explain a dead 19 V rail?
Yes. A direct GND–Vout short forces 0 V and can keep the PSU latched off. Clear the short and retest under light load. [Elektroda, Luis Cruz, post #21670807]
Is a fluctuating no‑load voltage normal on a universal adapter?
Small oscillations around 19 V (for example, 18.5–19.5 V) can appear, but large sags under load indicate regulation trouble or insufficient rating. Replace poor‑quality units. [Elektroda, Luis Cruz, post #21670815]
